Old 01-17-2009, 07:31 PM   #15
easyride's Avatar
1977 27' Overlander
1963 19' Globetrotter
Naples , Florida
Repair moen faucet
Originally Posted by rich1 View Post
I too have this same model that must be 18 years old or more. Moen does not recognize the model. If you have any success with your unit let me know where you got the info.
Rich (rich1)
that faucet has been discontinued,to repair is very easy,pull off center cap,remove screw,handle comes off,remove center cap nut,remove clip,pull cartridge using moen tool,[home depot should loan one with a deposit ] install new cartridge with the hole in the brass part of the stem to the back of the sink,now while you are in there you might as well pull spout and change o-rings apply a little grease and put it back together.
hope this helps.Plumber Dave
easyride is offline   Reply With Quote
Replacing kitchen faucet Sovereign86 Sinks, Showers & Toilets 5 09-13-2007 06:57 PM
Kitchen Faucet Repair hhessig Sinks, Showers & Toilets 2 05-23-2006 03:16 PM
Installed new kitchen faucet! Stefrobrts Fresh Water Systems 18 07-16-2004 11:33 PM
kitchen faucet leaking Stefrobrts Fresh Water Systems 10 03-16-2004 09:44 AM
Kitchen Faucet Repair niftypkg Sinks, Showers & Toilets 13 09-27-2002 05:02 PM
