Old 02-09-2007, 08:27 AM   #15
Tarheel's Avatar
2001 34' Limited S/O
Moyock , North Carolina
Images: 21
Go with what you are comfortable with, I am more comfortabe with copper, but mine is all pex and it is working great. The 74 was all copper sweat fittings and I had no problems with it either. They are both good systems.
Keep the shiny side up.
WBCCI # 348
Past Region 3 President
Past President Tidewater Unit 111
Rick Bell in "Silverbell"
Tarheel is offline   Reply With Quote
Old 02-16-2007, 03:26 PM   #16
hzbdad's Avatar
1968 17' Caravel
Birmingham , Alabama
pex vs copper
Kathy,
Had the same issue on my 68 Caravel. Really thought way too much about it, but that's the way I do things.
I used pex with push fittings. (Sharkbite is one type) I haven't tested yet, as the low is 20 degrees this week. Pex is cheap. Push fittings are expensive compared to clamp fittings + tool.
Ultimately I want to use the thing, so I went for speed (pex/push fittings) and low skill. Pex and clamp fittings are speed and maybe a little more skill, and then copper is for plumbers.
By the way, you sound like the person who called me in Alabama about my 64 Safari...in grad school and all. Glad you found one!
Ken
hzbdad is offline   Reply With Quote
Old 03-13-2007, 09:37 PM   #17
1973 20' Argosy 20
Lampasas , Texas
Originally Posted by Chiquita
Does anyone have the plumbing diagram for an argosy? I am trying to redo my plumbing but pcs. were missing so I am not sure where everything goes..
I just yanked the plumbing from my 73 20' argosy. The only tricky part is the kitchen sink. The bath, lav and toilet all run from the back closet behind the plastic panels. The kitchen runs around the shower pan and I had to remove the shower to replace. I'm going w/ Pex. If you remove the bathroom sink and panel behind the toilet and shower, it's easy to figure out. I will have some pics if you are interested.
scottmeri is offline   Reply With Quote
Copper vs. PEX ckeysor Fresh Water Systems 19 07-11-2007 12:03 PM
need to replace a radiator cap stuart1 Mechanics Corner - Engines, Transmission & More... 1 10-28-2002 02:12 PM
Copper Canyon (Barranca del Cobre) Pahaska On The Road... 0 07-25-2002 07:14 PM
Replace copper water lines in '61 Bambi 61BambiCanada Fresh Water Systems 1 05-22-2002 06:04 AM
What tires to replace with? Charcigar Tires 1 04-09-2002 01:08 PM
