Old 04-24-2009, 07:19 AM   #1
1977 31' Sovereign
Manchester , New Hampshire
Images: 33
Is there a back flow valve on my water pump?
Hey folks well I lost the pictures of how the plumbing configures from the back plumbing to the front . I know I can figure it out but I have one question when hooking up city water what prevents water from going through the pump into the fresh water tank is there a back flow valve in the pump OR whould there be a shut off valve installed to prevent it? I have a new shurflow 4.0 gm pump .
1976 Airstream Sovereign International Landyacht (renovating)(found DOM plate said 1976)
1968 Airstream Caravel 17 footer
2004 Nissan Titan with BT package
K/N Cool intake air
Duel power exhaust
Mrcrowley is offline   Reply With Quote
Old 04-24-2009, 07:26 AM   #2
There should be a separate "check valve" out side of the pump.
At least that's how the trailer was originally equipped.
One check valve keeps city water pressure off the pump. and another check valve keeps the pump pressure from escaping thru the city water hose connection.
Check valves sometimes, fail and must be replaced.
Some pumps have a check valve, some do not.
Old 04-24-2009, 11:50 AM   #3
Ottawa , ON
Does anyone have a good clear photo of what one looks like, by the way?
Old 04-24-2009, 12:16 PM   #4
This is the original check valve that Airstream used in your trailer.
Old 04-25-2009, 03:45 AM   #5
1977 31' Sovereign
Images: 33
Ok is this connected to wherer the city water comes in?
I think I have seen this on the outside of trailer.
K/N Cool intake air
Duel power exhaust
Old 04-25-2009, 10:06 AM   #6
Ottawa , ON
Hmm, not much to it, I wouldn't have taken that for a valve of any sort at a casual glance.
Thanks, Andy
Black Water Tank Valve Open but no Flow... dbaverb Waste Systems, Tanks & Totes 20 07-15-2009 09:19 AM
Flow rate from pump Cracker Water Heaters, Filters & Pumps 5 07-19-2004 06:53 AM
Shower Regulator or Back Flow Valve GStephens Fresh Water Systems 19 07-08-2004 09:56 AM
Water flow question... Sneakinup Waste Systems, Tanks & Totes 1 05-19-2004 06:20 PM
No water flow Michael W Plumbing - Systems & Fixtures 4 10-12-2003 08:26 PM
