10-04-2015, 09:57 AM
2004 19' Bambi
2010 23' FB Flying Cloud
Bridger-Teton
, Wyoming
Is anyone else have an obnoxiously loud water pump?
When it started to get cold I started to fill the interior tank so my hose won't freeze. The water works fine and the pressure is good but the pump is really loud. Is this common? Is there a quieter pump on the market?
10-04-2015, 10:39 AM
Biloxi
, Mississippi
My pump is only on when using water from the tank and I don't really notice it then.
MICHAEL
10-04-2015, 10:44 AM
2014 27' FB Eddie Bauer
Chelsea
, Michigan
You may have air in the lines. Let the pump run for a few minutes without shutting it off to bleed the lines. The stock Airtream water pump should emit a mild rumble when running.
Bob Martel
WBCCI# 5766
10-04-2015, 11:13 AM
2015 30' International
2009 27' FB International
2007 25' Safari
Greensboro
, North Carolina
Very noisy
Yup, mine is terrible. However, I have used some foam pipe insulation for the various loose pipes rattling around and this has decreased the noise considerably. I am installing a SHURflo 182-200 Pre-Pressurized Accumulator Tank in the line as well, am told this reduces some of the cycling and noise.
I suspect the cycling is dirt or foreign material in the line, but doubt this contributes to the noise.
Oh well....
Happy trails and Good Luck
AIR #31871 KQ3H
www.fantinesvoice.com
10-04-2015, 12:43 PM
2012 25' FB Flying Cloud
Celina
, Ohio
Check to see if your pump is connected directly to PEX tubing. If so go to your local hardware and buy a 20" hose and install it between the pump and the PEX on the out-going side. If you read Shur Flo manual it says not to connect pump directly to hard tubing, a thing called " water hammer" happens and the soft hose will absorb it
Gary
10-04-2015, 12:59 PM
2012 30' International
1997 25' Safari
1967 20' Globetrotter
Burlington
, Ontario
Oh well....
The water pump in my Safari was ok but the pipes were rattling against something underneath and I was not going too remove the belly pan in order to find the source. I stuffed in an accumulator tank from Home Depot. Accumulator tanks are like batteries. One can always use more capacity once you become familiar with the possibilities. Watts Model # DET-5 Internet # 100677607 Store SKU # 594885 8.5 in. W x 11.5 in. D x 8.5 in. H Pre-Pressurized Steel Water Expansion Tank. The SHURflo works nicely but the beast from Home Depot is better. I stuffed it up under the sink. Jim
10-04-2015, 05:00 PM
2007 28' International CCD
Springfield
, Missouri
I replaced my noisy cheap knocking factory pump with a Shurflo Revolution.More water pressure and quiet.About $100 and 15 mins.No expansion tank needed for me.
10-04-2015, 09:01 PM
2004 19' Bambi
Bridger-Teton
, Wyoming
Thanks for all the recommendations...
Yeah, no air in the lines. And like I said, pressure is good and all works well. But man, this thing is noisy and does rattle some pipes.
10-04-2015, 09:07 PM
2004 19' Bambi
Bridger-Teton
, Wyoming
Oh well....
Msmoto,
Is this what you're talking about :
http://www.amazon.com/SHURflo-182-20.../dp/B000N9VF6Q
And how does this work? I'm interested in hearing from people that have used this and if it has solved noisy pump issues.
10-04-2015, 09:16 PM
2008 27' International FB
Venice
One thing I would check for is the mounting of the motor should be a spongy rubber to absorb the vibration from the motor. Simple fix, good luck.
Bill and Janice, We're lovin' it! (Airstreaming)
Airdreamers
WBCCI #8880
AIR #41310
10-04-2015, 09:20 PM
1995 25' Excella
xxxxx
, xxxxxx
I agree. Mine is on carpet. It is very quiet.
10-04-2015, 10:50 PM
2007 25' Safari
Greensboro
, North Carolina
@Veg hed
Yes, that is the pressure thing. I think installing this when I pull the pump out and remount it after cleaning, will reduce the cycling problem and allow the pump to run for longer cycles during water use,e.g., during a shower.
Once installed, I will report back.
Ms. Tommie Lauer
AIR #31871 KQ3H
10-05-2015, 10:45 AM
2002 30' Classic S/O
Garden Valley
, Idaho
Yes, and I changed it out to a better pump and it's faster and more quiet.
2008 F-250 4X4 Lariat V-10
2007 Kubota 900 RTV
1996 Ford Bronco
2007 Lincoln LT
1977 31' Sovereign
Lynnwood
Water pump should be mounted on rubber cushions/mounts. Those cushions should absorb the noise you're talking about.
Check mounting screws for proper tightness (not too terribly tight) and cushions for being smashed (due to over-tightened screws).
Tom
10-05-2015, 07:39 PM
Regular Guy
1978 31' Sovereign
Hot Springs
, Arkansas
Mine is noisy too. It works great.
10-05-2015, 07:47 PM
Durango
Originally Posted by veg hed
The standard pump from Airstream is a piece of crap. It is noisy no matter how you mount or even if you use the accumulator. At least, mine was.
I replaced it with the ShurFlo Revolution and never looked back. It is a bypass pump and runs much quieter, has more pressure, and pumps at a higher volume.
If you mount it on carpet and insulate some of the pipes you can still hear it run but it is many times quieter.
10-05-2015, 09:06 PM
Sneedville
, Tennessee
Which one, there seems to be a few different models called Revolution.
10-05-2015, 09:43 PM
Portland
, Oregon
Thanks for starting this thread, VegHead.
In my 2015 16' Sport I was shocked by how loud the water pump was. I quickly discovered that it had been installed so that it was in direct contact with the fresh water tank. This means that whenever it comes on it bangs agains the side of the tank like a big drum! I moved it over a bit and padded it with some foam, which has helped, but I agree with RVDreamer, it's still ridiculously loud.
I'm shopping for something quieter and would also be very interested in which model of the Shurflo Revolution you got. Thanks!
10-05-2015, 11:03 PM
2015 25' Flying Cloud
Eugene
, Oregon
I have a new (5 months old) Flying Cloud and we have tried the water pump once. It came one every single time we opened a faucet and the noise was not pleasant. Since we were at a camp that had a few water sources to fill your buckets, we were supposed to use our water pump. Since it was late in the season and I was close to the water source, I simply attached a "Y" and ran two hoses from one end to my rig, thus eliminating the need for the water pump while still allowing others to use the water source. Fortunately, there were no campers nearby so it never became an issue. Strangely, everyone else in the camp was doing the same thing. If I were to do more dry camping, I might look into some of the suggestions above since the pump is noisy.
10-06-2015, 12:49 AM
2019 27' Tommy Bahama
London
, Ontario
We find the Shur Flo pumps to be very inconsistent in noise level. Some are quite good and others are terrible. On about half of the Airstreams we deliver we change the pump to a Flojet Quad valve pump. This pump is much quieter. It also has a bypass valve in it so at partial water flows the pump runs continuously and delivers smooth pressure output. It is by far the easiest fix for a loud pump.
Andrew T
Andrew Thomson London, Ontario
"One test is worth a thousand expert opinions." Tex Johnston, Boeing 707 test pilot
