Old 06-14-2011, 06:43 PM   #1
2011 Interstate Coach
2010 22' Interstate
Reston , Virginia
Interstate Water Pump
Hi, new member here. we have a 2011 Interstate. The fresh water pump went out after 2200 miles. I believe the fresh water tank needs to be drained in order to replace the pump...Does anyone know how to drain the fresh water tank so that the pump can be replaced? Thanks for the help!
VAinterstate is offline   Reply With Quote
Old 06-14-2011, 08:28 PM   #2
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Welcome Aboard
There should be a plastic petcock on the curbside between the axles, loosen the fill cap, it will still take awhile to drain.
I think if you pinch the supply line to the pump you should be able to remove it without draining.
I had to repair the wiring on ours the first time out, just put a towel in there to mop up the little water that comes out.
Have you notified AS?, they sent me a replacement to install after the makeshift repair.
“Not enjoying the Network News Broadcasts ?…ask your Doctor." 🤪
RLC
"The hardest thing about Airstreaming, clearing your head and accepting how others feel it’s supposed to be done"…..
Amanamus
"Tahawus"
Old 06-15-2011, 08:30 AM   #3
2010 22' Interstate
Reston , Virginia
Thanks for the reply
Robert,
Thanks for the feedback. Two questions...how do you pinch the supply line and who is "AS"?
Old 06-15-2011, 08:38 AM   #4
aftermath's Avatar
Spokane , Washington
AS is "Airstream". Since your Interstate is new, it might be best to contact the company for warranty work.
If the supply line is flexible you can "pinch" it closed by using a vise grip type of pliers.
aftermath is offline   Reply With Quote
Old 06-15-2011, 08:53 AM   #5
Originally Posted by VAinterstate View Post
Robert,
When I had to remove mine we were camping, I had to improvise, just folded the line and held it together with a zip-tie.
Sorry about the acronym.....
AS= Airstream=JC=Jackson Center
SOB= some other brand
TV= tow vehicle
curbside=right side of trailer
streetside= left side of trailer
WD= weight distributing hitch
WD bars=hitch bars that are tensioned to transfer tongue weight.
receiver= TV portion of your hitch
stinger= removable portion of the hitch that fits over the tongue ball.
Well you get the idea...you'll get the hang of it.
RLC
Amanamus
"Tahawus"
Old 06-15-2011, 09:12 AM   #6
Gainesville , Florida
You are talking about the class B coach, correct? The older ones had a couple of valves just inside the right rear door. One of those was a drain valve, but I cannot remember if it drained the whole tank or just the lines. There were also valves on the other side. jim
2011 interstate, water pump
Interstate coach water pump problems solar-guy Sprinter and B-van Forum 10 06-03-2015 03:51 PM
No water from pump Castaway Fresh Water Systems 10 04-13-2011 09:59 PM
Water pump leaking between head and motor Ezmoneybcs Water Heaters, Filters & Pumps 4 03-20-2011 07:32 AM
Is it a water pump or an electrical problem? Taj MaHaul Water Heaters, Filters & Pumps 7 01-23-2011 08:20 AM
Panel indicator light for water pump and Water heater DJW Water Heaters, Filters & Pumps 3 01-05-2011 08:01 PM
