Old 12-16-2008, 03:18 PM   #1
adonh's Avatar
1976 31' Sovereign
Missouri City , Texas
installing pump winterizing kit
After about 9 years I was able to install a new water pump and fix the suction line to my fresh water tank this year. Now I want to install the Camco RV pump converter winterizing kit so that I can suck the antifreeze from the container through the pump to winterized my fresh water system lines, including my RV 500 tankless water heater. Heres my question, on my 1976 31' sovereign the water pump is under the kitchen counter behind the stove. Not the easiest thing to get to. The instructions show connecting the 3-way T valve to the intake connection on the pump. I can get to the pump for the install of the 3-way T valve but for routine winterizing I don't want to dismantle the kitchen counter each time. Has anyone come up with a work around. I can see the pump from the small side access door to the 12V fuse panel and could maybe reach in and turn the 3-way valve but it would be close.
Don
adonh is offline   Reply With Quote
Old 10-20-2012, 09:28 AM   #2
1993 30' Excella
1976 25' Tradewind
Flushing , Michigan
Did you ever come up with a solution? I am not sure there is enough room to install the pump converter kit, much less easily use it to winterize in my 1993 30' Excella--water pump location is beneath the "floor'" of the wardrobe amongst all the furnace outlet tubing lines. Any ideas are welcome.
steve46 is offline   Reply With Quote
Old 10-20-2012, 09:45 AM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
You could connect longer hose sections to the input and out put side of the "T valve" and bring it out to a location easier to get to when you winterize. Put a short hose on the winterizing side of the "T Valve" and just cap it off. Now during winterizing you would have easy access.
If you have a filter before the pump make sure that it is after the "T Valve as it has water in it and will freeze if it is on the suction side.
You mention the heater. Consider installing a By Pass Kit on the water heater and draining it before you winterize. Saves 5 gallons of antifreeze.
2004 Excursion 4x4
Flojet RV Waste Pump Kit Dr. E Waste Systems, Tanks & Totes 12 10-01-2017 04:17 PM
Delay Winterizing/use heat pump 1cericks1 Winterizing, Storage, Carports & Covers 23 11-05-2008 11:07 AM
2003 22'CCD water pump winterizing rettoc625 Winterizing, Storage, Carports & Covers 3 10-07-2007 08:09 PM
rebuild kit for water pump 76 sovereign chris's 67 Fresh Water Systems 2 03-06-2007 08:18 PM
Murphy and I are Winterizing the Argosy. Need Pump Motor. RBolton Winterizing, Storage, Carports & Covers 12 10-24-2006 09:56 AM
