Old 02-08-2004, 03:35 PM   #1
Unhappy Installing fresh water tank
We just bought a 1968 Airstream Globetrotter and it is completely missing the fresh water tank (we were aware of this). As far as we can tell from the owner's manual and inlet pipe, the tank should go under the front goucho. Is this correct? I was going to have my brother weld a stainless steel tank to fit in the space, but i'm unsure of what the dinensions should be. Is there a better way, such as one that is already built and will fit right in?
Any help would be great. Thanks.
--warren & cindy
1968 Globetrotter LandYacht
warrencindy is offline   Reply With Quote
Old 02-08-2004, 03:51 PM   #2
Warren and Cindy
We have the original water tank for your trailer.
Providing a serial number will assure that you have a 68.
Tanks are different for each year.
Old 02-08-2004, 04:27 PM   #3
WOW - thanks for the quick reply.
We are very excited...two questions though...
Where can we find the serial number? I saw somewhere that some airstreams list the serial on the front, behind the LPG tanks...
How much would the tank cost (incl. shipping)?
Thanks again.
Old 02-09-2004, 08:23 AM   #4
The serial number plate is forward of the door and below the window, "IF" you have a 68 trailer.
That number should start off as "O208 followed by an "S" or "J" followed by three numbers.
Old 02-09-2004, 10:56 AM   #5
I believe you are correct...i remember seeing one there. The airstream is not right here, so it may take me a couple days to get it. I'll let you know ASAP.
Thanks again!
Old 02-10-2004, 10:21 AM   #6
Thumbs up Found serial number
Hi Andy,
Thanks for being so patient while we located our serial number!
There were two sets of numbers under the window: D129 FH and 0208J587. Hopefully your tank is for our globetrotter. Let us know if we've got a match.
Thanks again,
Cindy & Warren
Old 02-17-2004, 02:59 PM   #7
Cindy and Warren.
We have the correct tank for your 68.
Just got back this AM.
