Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Fresh Water Systems
Old 09-27-2009, 03:00 PM   #1
WILDRTEXAS's Avatar
Profile:  1970 27' Overlander
ARLINGTON , TEXAS
Send a message via Skype™ to WILDRTEXAS
I'm drowning with this plumbing maze ... PLEASE HELP :)
Hello,
I am attempting to replace the copper plumbing with Pex.
I am fairly handy but, I'm stumped with this maze. Do I really need all 5 of these cut off's?
The 1st photo (left to right) has a cut off that I think comes out of the fresh water tank (?)
The 2nd goes to the sink (with another cut off) Hot or cold Im not sure. The 3rd has another cut of that goes to hot or cold?? NOT SURE
If you look below the 3rd cut off, it has a short piece of copper that slips thru a hole in the floor (pulled up for photo), on the bottom side, below the AS its an open pipe. Is this normal? If so, what is this? Also, the copper lines that appear to go to the sink faucet are different sizes. Is this normal? Im really lost. Does it really have to be this complicated or is this just pieced together? Any suggestions to simplify this with pex is so appreciated. THANK YOU ALL!!
He is your friend, your partner, your defender, your dog. You are his life, his love, his leader. He will be yours, faithful and true, to the last beat of his heart. You owe it to him to be worthy of such devotion...
Taylor 1/20/96 - 11/28/08
WILDRTEXAS is online now   Reply With Quote
Old 09-27-2009, 04:36 PM   #2
mello mike's Avatar
Profile:  1972 31' Sovereign
Phoenix , Arizona
Images: 14
The three red-handled valves are actually drain valves. All three are connected to that pipe that runs out the bottom of your Airstream. One valve drains your fresh water tank and the other two drain your hot and cold water lines. Not sure if you need to have two in the kitchen to drain your hot and cold water lines since there are also two in the bathroom. The other valves in your pic appear to be shutoffs for your hot and cold water lines running to your kitchen sink. It's up to you whether you want these there or not. I would.
Sterling - 1972 Sovereign Intl (RB)
Eddie - 2003 Ford Excursion (6.0L PSD)
Prodigy Brake Controller / Equal-i-zer Hitch / Honda EU2000i x2
Airstream Life Contributor
WBCCI 4CU #5661/AIR #5661
My Refurb Blog: UPDATED!!
http://mellomikesairstreams.blogspot.com/
Part wanted: 70s Kitchen Counter Unit
mello mike is offline   Reply With Quote
Old 09-27-2009, 07:38 PM   #3
Minno's Avatar
Lexington , Minnesota
The hot and cold water drain valves are installed at the low points of the water system. My 72 Sovereign, did not have low point drains in the bathroom, only by the water tank as you have. If you eliminate these from the kitchen, then you will have a few inches or feet of water pipe between the tank and the pump that may not drain completely for winterizing your trailer. Might not be an issue in Texas though... But it could be for a future owner of the trailer if they move it up North. So, I would keep the 3 drain valves.
I’m with Mike on eliminating the shut valves to the kitchen skin. That seems like overkill in a trailer, where all you need to do is shut off the pump or city water supply to replace or repair a faucet.
Chris
Old 09-29-2009, 10:39 AM   #4
WILDRTEXAS's Avatar
ARLINGTON , TEXAS
Chris
I had planned moving the 3 valves up for better access UNTIL you said they are installed at the low points in the water system. NOW makes sense to me. Thanks for the info. Im just learning about my AS. I really appreciate everyones help. Really would be lost without all the help. THANKS!!!!
Old 09-29-2009, 03:15 PM   #5
mello mike's Avatar
Phoenix , Arizona
Images: 14
That's interesting, Chris. I wonder why my Sovereign has two sets of drains in the Kitchen and bathroom? Seems like overkill to me. I think I'll eliminate one set probably the ones in the kitchen.
Old 09-27-2009, 07:43 PM   #6
jpeterman's Avatar
Profile:  1972 27' Overlander
Graham , North Carolina
all that is good info, because I am fixing the hot and cold water lines that frooze last year from not knowing to open all three drains
"AIR 17559"
wear it out, don't rust it out
Jerry
jpeterman is offline   Reply With Quote
Old 09-27-2009, 08:50 PM   #7
azflycaster's Avatar
Profile:  1975 25' Tradewind
Phoenix , Arizona
Images: 62
When the PO PEX'd my trailer all of the drains except for the fresh water tank were eliminated. The PO pumped antifreeze into the system and bypassed the water heater. The system is leak free.
It was 108 degrees in Phoenix today, still a little early to think about winterizing.
Richard
Charter Member Four Corners Unit
Old 09-30-2009, 02:34 PM   #8
InsideOut's Avatar
Profile:  1964 19' Globetrotter
1956 22' Safari
Only Airstreamer in Edgewater , Colorado
Images: 87
Yeah, but aren't you headed to Colorado? You may need to take care of that before you leave here in a couple of weeks...especialy if you are headed up to the mountains after the rally.
You never know.
Shari
RMVAC | WBCCI DenCO Unit | Maxwell | Birdy
Old 09-30-2009, 06:21 PM   #9
Phoenix , Arizona
Images: 62
You never know.
Shari
We will keeping a eye on the temperatures on our return trip from Fort Collins.
Richard
Old 09-27-2009, 08:57 PM   #10
DaveFL's Avatar
Profile:  2000 Land Yacht 30(31') , Inverness, between the Withlachochee River and the Gulf of Mexico, Fl
There is a good reason to be able to drain all besides temp, if you take on some bad water, much easier to flush system by just draining. Can also use flushing action after bleaching tanks and pipes.
Old 09-29-2009, 11:10 AM   #11
Profile:  1966 22' Safari
Keller , Texas
Suggestion: If you haven't already done so, draw a schematic of your entire water system, separate cold and hot, and figure the whole thing out before you cut out the copper. We replaced damaged copper with PEX in our Safari, and many times the drawings were the only thing that saved us big mistakes. You'll find places where the PEX fittings won't fit exactly where the copper ones did, and you'll have to re-design a bit to do the same thing.
Also, if you're using the crimped copper rings to secure the PEX, be sure to plan the last crimp at a place where the tool will fit and operate in the space you have. We had to pre-fabricate several assemblies outside the tight spaces and then install the whole thing together.
Lots of planning and head scratching, but it's a great system when you get it done.
Old 09-30-2009, 12:11 PM   #12
Minno's Avatar
Hi Mike,
I'd be more tempted to eliminate the ones in the bathroom. Then you'd have your low point drains and tank drain all nicely together in one spot. My service manual shows low point drains in both the bathroom and kitchen, so maybe a PO eliminated the bathroom ones at some point before we got her. Heaven knows there were enough patches in the water system for anything to be possible!
Chris
Old 09-30-2009, 01:35 PM   #13
Ganglin's Avatar
Profile:  1971 27' Overlander
Gahanna , Ohio
Images: 13
Just an added thought on the front and rear drains. We follow the manual instructions to over-kill when draining the trailer (even though I pump all the lines full of antifreeze). I have no intention of having to replace the copper with anything else.
Open all faucets - front and rear drains - and the exterior faucet the PO added next to the incoming water line and let it drain - as well as the water heater.
Fresh water tank has never had water in it until this year so it was always bone dry.
Then (per the manual) jacked the unit up until the elect. jack maxed out and let it drain. Then let the jack down as far as it will go.
Without fail we have always had additional water still drain from the front low points when the nose was lowered as the last step......
OHIO - WE ARE THE MOTHER SHIP
Gary
Old 09-30-2009, 01:51 PM   #14
Minno's Avatar
Yup - I can see that happening. When you raise the front of the trailer, the water lines that run around the rear end are going to be lower than the drain valves in the bathroom. Once you lower the front end, then the front drain valves are lower than the rear, so the remaining water drains out the front valves.
Chris
Plumbing rollingbubel Fresh Water Systems 2 02-23-2009 12:22 PM
Need help with plumbing. netlace Waste Systems, Tanks & Totes 8 11-15-2008 05:15 PM
Why shouldn't I do this with the plumbing.??? purman Plumbing - Systems & Fixtures 9 09-12-2008 02:42 PM
trying to figure out the health insurance maze rec Full-Timing 20 02-12-2008 04:27 PM
Plumbing my A/S blucloud Fresh Water Systems 4 06-11-2004 07:16 PM
