Old 05-27-2010, 12:28 AM   #29
Roblin , MB.
Hi WILDRTEXAS,
I believe you can purchase Blue and Red coloured pex. When I replaced the copper with pex in our '74 - 31' side bath our local hardware did not have pex in the two colours. I purchased 2 areosol cans of paint - 1 blue and 1 red and sprayed long lengths of pex before making any cuts. I found this helped a lot to have the coloured lines when you ran them in the trailer and attempted to make connections while standing on your head and balancing a flash light and crimping tool. Just a thought for you on your A/S.
Regarding Antifreeze - it is cheap vs. repairing / replacing plumbing.
Don't do away with shut offs under sinks, etc. Someday if you have trouble with a tap and cannot get replacement parts or a new fixture for a few days you can shut down the individual tap that is faulty and still run your pressure system to keep other taps, toilet, hot water tank, etc operational.
Just my 2 cents worth!!
nairnchyz is offline   Reply With Quote
Old 05-27-2010, 12:44 PM   #30
1956Safari's Avatar
1956 22' Safari
Ossining , New York
Images: 16
Thanks Bob and Shari. You both are so neat! I hope mine comes out half as well. J
1956Safari is offline   Reply With Quote
Old 05-27-2010, 01:30 PM   #31
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
Jaime ~
Here's a bit more info on ours...hope this helps! I'm sure yours will come out great too!
Shari
Old 05-08-2011, 03:13 PM   #32
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
revive this thread
Shari...where did you get the check valve in your system......what kind is it...etc., etc.
Plumbing rollingbubel Fresh Water Systems 2 02-23-2009 11:22 AM
Need help with plumbing. netlace Waste Systems, Tanks & Totes 8 11-15-2008 04:15 PM
Why shouldn't I do this with the plumbing.??? purman Plumbing - Systems & Fixtures 9 09-12-2008 01:42 PM
trying to figure out the health insurance maze rec Full-Timing 20 02-12-2008 03:27 PM
Plumbing my A/S blucloud Fresh Water Systems 4 06-11-2004 06:16 PM
