Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Fresh Water Systems
Old 03-15-2015, 09:19 AM   #1
jmalexan's Avatar
1978 25' Tradewind
I1978 International Tradewind 25'
Name:	ImageUploadedByAirstream Forums1426432617.016429.jpg
ID:	234213 can someone tell me want the two smaller holes are on this freshwater tank? I'm assuming the bottom one is where I pull the freshwater from connected to a waterpump? And the gray one is where I fill the water. And I'm assuming the top one is a vent but I'm not sure. Also are these the only 3 ports on this tank? I can't see the rest with out chopping the floor up.
Any help would be great . Trying to set up fresh water.
James
jmalexan is offline   Reply With Quote
Old 03-15-2015, 04:34 PM   #2
2007 22' International CCD
Top small one is usually vent. Gray one is the fill hose to the inlet. Vent also goes there on some fill doors with a screened vent fitting. Bottom of tank goes to pump. It's fairly standard.
Old 03-15-2015, 04:35 PM   #3
Should be a drain valve somewhere accessible from under the tank outside.
Old 03-15-2015, 10:06 PM   #4
jmalexan's Avatar
1978 25' Tradewind
Thanks for the guidance. I just wanted to make sure. I didn't notice a drain plug but I'll look harder.
James
Old 03-31-2015, 05:14 PM   #5
jmalexan's Avatar
1978 25' Tradewind
Does anyone know what this powers? It's right next to the antenna.Click image for larger version
Name:	ImageUploadedByAirstream Forums1427843685.548933.jpg
James
Old 03-31-2015, 06:39 PM   #6
4RXLA's Avatar
1977 31' Excella 500
West Sacramento , California
Images: 33
My 77 Excella 500 came with a motorized tv antenna. The switch for it was located on the curbside wall just below the light switch for the outside scare light. Perhaps that's 12v power going up there??
4RXLA is offline   Reply With Quote
Old 03-31-2015, 07:08 PM   #7
jmalexan's Avatar
1978 25' Tradewind
Thank you! That makes a lot of sense it does run to that side of the trailer where 12v is hooked up. I think this was spliced into the 12v outlets? I think
James
1959 Airstream Tradewind :: 1959 Airstream Tradewind steveirving Airstream Registry Discussions 1 07-27-2021 06:15 PM
1963 Tradewind :: 1963 Airstream Tradewind Fredrick00 Airstream Registry Discussions 0 06-27-2014 08:37 AM
"Firefly" 1960 Tradewind :: 1960 Airstream Tradewind 2vets Airstream Registry Discussions 0 08-19-2011 08:30 AM
