Old 06-07-2010, 10:28 AM   #1
BessieB's Avatar
1997 21' Excella
Carson City , Nevada
Question husband did not winterize
Gosh you all,
My husband did not winterize and now he gets to tackle that failure. And then he looks at me and asks why I didn't. Geeeeeee!!!!!!!! Anyway, where does one start? What is all the access? We have a 97 21fter and leaks galore. So underneath there is access panel so he says, but what about inside? He did put in a new faucet in the lavatory since we both didn't like the original and he wasn't impressed with the access underneath there.
So any starting hints?
I've got the manual in the house now.
Thanx,
BessieB is offline   Reply With Quote
Old 06-07-2010, 10:50 AM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
Most of the water piping should be above the floor. There may be one traverse under the floor depending on your layout. Piping generally brakes at an elbow so I would start by inspecting what you can see so and repair that which you can see. For plastic pipe Sea Teck or Shark Bite fitting are easy to install.
Once you have the obvious fixed I would apply low air pressure 25 lbs or so and lessen for leaks. This could be a major job and one you may want to ask your insurance carrier about. Not sure they will cover neglect but it is worth and ask.
The traps may also be broken. The one under the shower will be the killer.
The tanks should be OK unless they were quite full.
2004 Excursion 4x4
Old 06-07-2010, 11:12 AM   #3
bobfowler's Avatar
1972 Argosy 20
Middletown , New Jersey
Images: 14
YIKES! Having repaired blown copper in the past, I feel your pain. You probably have more than one split pipe (yes, pipes DO split wide open). You may want to consider pulling out the copper and installing Pex. I had to replace every inch of plumbing in my 72 Argosy. It wasn't that hard of a job at all, but my Argosy is probably a simpler trailer than your '97. One thing we did was to replace all of the gate valves with ball valves. I also made a manifold that resides on the rear wall under the bathroom sink with shutoff valves for every fixture in the trailer. A little overkill, but worth the effort.
Bob Fowler
Some people are like Slinkies. They're really good for nothing, but they still bring a smile to your face when you push them down a flight of stairs.
TAC - NJ-007
bobfowler is offline   Reply With Quote
Old 06-07-2010, 11:21 AM   #4
BessieB's Avatar
1997 21' Excella
emptied water
Hi,
Tanks should be empty without being blown with compressor. Also in the cold when the trailer went out hunting last December, it was way cold. Anyway, the valve that drains the water broke then and that will need to be replaced. Like 12 degrees or less out there and that plastic just broke like a paper fold.
thanx......
Old 06-07-2010, 11:22 AM   #5
bobfowler's Avatar
1972 Argosy 20
Images: 14
This is the city water/system drain manifpold I made. It resides in the bathroom closet.
This is my under-the-bathroom-sink manifold that feeds the bathroom sink, shower, and kitchen sink. (cold water lines are color-coded with blue painter tape).
You'll note we used braided stainless steel supply lines for everthing. The lines to the kitchen route behind the shower pan and are braided SS all the way to the faucet in the kitchen.
I don't have any pix of the new pipe installation by the water heater, but essentially I made a manifold for that as we. The cold water line from the pump is plastic to a barbed connector on the copper pipe manifold at the water heater. The far end of that manifold has 3/4" threaded connectors from which more braided SS lines run to the city water/system drain manifold.
Bob Fowler
TAC - NJ-007
Old 06-07-2010, 11:27 AM   #6
bobfowler's Avatar
1972 Argosy 20
Images: 14
Originally Posted by BessieB View Post
Hi,
thanx......
I had to replace mine last weekend. Is this the one you need?
Bob Fowler
TAC - NJ-007
Old 06-07-2010, 12:14 PM   #7
BessieB's Avatar
1997 21' Excella
valve replacement
Yes,
It looks about right, thanx for the link. I started unscrewing but never finished. These posts are all great.
My husband was thinking of using that very piping, the metal corrugated stuff if that is what it is called.
Can you imagine how smart I can get after all this?
Thanx
Old 06-07-2010, 12:58 PM   #8
Janet H's Avatar
1964 26' Overlander
1964 19' Globetrotter
Eastern , Washington
Images: 90
We had to do the same repairs to our Argosy when we first got it and used PEX on everything It's worth buying the fitting crimper although you can rent one. Not a fan of the bayonet fittings....
We found split copper lines, broken toilet valve and faucets, but the tanks and drain traps were ok. On many models the toilet valve is replaceable.
AirForums Custom Search
Janet H is offline   Reply With Quote
Old 06-07-2010, 01:56 PM   #9
1 Rivet Short
1989 25' Excella
By The Bay , Rhode Island
husband did not winterize?
Yikes!
If your Husband did not winterize you should be sure to check his plumbing thoroughly; apply pressure and check for any drips, leaks, or sagging anywhere in the system. How old is the plumbing? When was it last drained? Is there a history of non-performance? A thorough examination of all components, including those hanging beneath the chassis should provide you with all the information you need to properly diagnose the system and hopefully get him up and running again!
Should this result in the system failing to rise to the occasion, there are remedies available. Many of them available on-line as my inbox indicates daily!
Good luck…and don’t report back with any details…
*Life is Good-Camping all around the Continent*
*Good people drink good beer-Hunter S Thompson*
BillTex is offline   Reply With Quote
Old 06-07-2010, 04:04 PM   #10
BessieB's Avatar
1997 21' Excella
Unhappy sytem worked great
I brought home an excellent functional trailer. So I have him reading this and hopefully the nose will go to the grindstone and he can tackle this. I really had some summer plans here......
Old 06-07-2010, 10:10 PM   #11
FreshAir's Avatar
1966 24' Tradewind
Placerville , California
We bought our Trade Wind from a family way up in Oregon 4 Aprils ago. Once it was home I set out to check out everything. Hooked up the garden water hose, turned the faucet on and before I could go into the trailer water was flowing out from every door, hatch and whatever. I ran back to the faucet and quickly turned it off. I then waded into the flooded trailer and located 6 split pipes from the galley to the rear bath! I had just had 2 hips replaced and Lynn was recovering from a stroke so we both had a mighty distraction and plenty of time to bring this trailor up to snuff by late summer.....the time we were permited to venture out onto the highways and camping. I can't say it was the physical therapy that our doctors would recommend but it was certainly the best mental therapy we could have wished for.
Neil.
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
Old 06-08-2010, 10:14 AM   #12
BessieB's Avatar
1997 21' Excella
oh my!!!!
So you tackled it? Good for you. Making progress here, the manual is in my husband's possession.
I made progress on the home front. I bought a little shop vac. I can see why hard floor is the direction. The rug is very impressive in how well it cleans up, but until we get home........... I even put down area rugs, but grit still gets tracked in. So this little shop vac will be mighty handy when out and about.
Old 06-09-2010, 10:37 AM   #13
BessieB's Avatar
1997 21' Excella
Making progress. My husband is trying to avoid but got him out there. So far it looks like it is just the pvc sort of stuff, just very brittle All looks original, which he was wondering about. So this he can handle. And I will get on the horn and order that valve part, that I know to do,
thanx all again......
Old 06-10-2010, 08:34 AM   #14
FreshAir's Avatar
1966 24' Tradewind
If hubby is a 'typical' guy he's loving the repair process. I did/am...new black tank...new water heater....new axles....new cork floor ....polishing....replacing bad oven with microwave............lovng it with camping too.
Neil.
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
455 cid
Help me convince my husband! BeckyT Member Introductions 26 07-07-2009 04:16 PM
a conversation between husband and wife wannaroam Upholstery, Blinds, Walls & Interior Finishes 18 11-14-2007 11:37 AM
Husband gone crazy rebel beck Our Community 27 03-25-2007 04:14 AM
Don't go on vacation without your husband... ccjackson Member Introductions 7 09-06-2006 04:58 AM
need help with concerned husband new2rving General Repair Forum 7 10-04-2004 07:29 PM
