Old 03-25-2010, 07:43 AM   #1
1978 28' Ambassador
Savannah , Georgia
How to remove valve stems
Trying to replace pressure release valve. In order to get to it I need to remove these red turn handles. One is pictured in the lower right corner. I've loosened the top nut and valve stem turns and then stops. Can these handles be removed? Any other suggestions on how to get to pressure release valve? Thanks. Jack
Skamper1 is offline   Reply With Quote
Old 03-25-2010, 07:51 AM   #2
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Wrong Nut
The top nut is just the packing gland. You should first open the valve by turning the handle counter clockwise. The unscrew the "bottom nut", the one right at the valve body. The whole assembly will come out of the valve body. When you reassemble it, make sure the valve is still in the open position, otherwise you could ruin the seat and or stem.
Old 03-25-2010, 07:53 AM   #3
Mikethefixit's Avatar
1977 27' Overlander
Trotwood , Ohio
Send a message via Yahoo to Mikethefixit
It was not necessary to remove the red handle or the nut under that. You have to unscrew the next nut down,which removes the valve from the body. Looks like from the picture thats gonna be easier said than done.Good Luck.
OPPSS sorry TG We were posting at the same time,Great minds think alike. LOL
Roger & MaryLou
___________________
F350 CREWCAB SW LONG BED
7.3 liter Power Stroke Diesel
1977 27ft OVERLANDER
KA8LMQ
AIR # 22336 TAC- OH-7
May your roads be straight and smooth and may you always have a tailwind!
Mikethefixit is offline   Reply With Quote
Old 03-25-2010, 08:28 AM   #4
1978 28' Ambassador
Savannah , Georgia
You people are great. Thanks. Have removed valve stems and even removed old pressure release valve. Thought the "below nut" was part of the valve. Was afraid to mess with that at first. The two valve washers look great so don't plan to replace them. Thanks again. Jack
Valve stems and TPMS cosmotini Wheels, Hubs & Bearings 8 08-06-2013 07:28 PM
Tire Valve Stems Airperson Tires 11 04-30-2011 05:22 AM
Valve Stems azflycaster Wheels, Hubs & Bearings 1 05-29-2008 07:17 AM
Metal valve stems jcanavera Tires 7 10-31-2007 11:12 AM
Valve Stems LKappenman Wheels, Hubs & Bearings 5 08-08-2002 08:34 AM
