Old 05-15-2017, 11:40 AM   #1
1958 22' Flying Cloud
portola valley , California
How to keep fresh water tank fresh and tasting good
Any advice on how to keep our tank as clean as possible and the water tasting good? Any items or chemicals we need for this?
All advice welcome and appreciated!
Thank you
Dianne
Driftin Di is offline   Reply With Quote
Old 05-15-2017, 11:49 AM   #2
prairieschooner's Avatar
1958 18' "Footer"
Idyllwild , California
We decided years ago to carry Bottled Spring Water. This followed our dogs getting ill while we were traveling in our Motorhome and will continue in the '58 Traveler. I do have a point of use RO System in the coach but the water where we typically travel is generally poor. I found that about a gallon/day is good for our drinking needs.
I am still using the original black iron tank in the Traveler so no plans to use it for drinking water.
If you have good city water it should have enough chlorine in it to keep the water for normal trips. If you choose to go that way then drain the tank & refill prior to camping. Otherwise you will need to use chlorine tablets & that doesn't appeal to me.
Steve
1958 California Built 18' #18-4092
http://www.airforums.com/forums/f106...on-122678.html
prairieschooner is offline   Reply With Quote
Old 05-15-2017, 11:52 AM   #3
Adventure.AS's Avatar
2017 25' International
Port Dover , ON Canada
Thank you
Dianne
You will need much less bleach to make water safe to drink than you might think.
Clorox company recommends: "If you have a tank with clear water that you simply want to make sure is safe to drink or use for human contact (hand washing, laundry, etc.), then you can follow the protocol for emergency disinfection of drinking water. In that case, the correct ratio of bleach is ½ teaspoon Clorox® Regular-Bleach per 10 gallons of water (or for a smaller size container, 2 drops per quart). Stir the bleach into the water and let stand 30 minutes. Properly treated water should have a slight chlorine odor—if not, repeat the dosage and let stand an additional 15 minutes.
Read more at https://www.epa.gov/sites/production...a816f15003.pdf
Ray B.
“One test is worth a thousand 'expert' opinions”
Sign at Boeing headquarters, posted by test pilot Alvin “Tex” Johnston, c1948
Adventure.AS is online now   Reply With Quote
Old 05-15-2017, 11:59 AM   #4
Long Island , New York
Thank you
Dianne
It depends on how old your tank is, and how it has been treated through the years, especially recently. The advice just posted is good for systems that are in perfect condition. If you want to "shock" the tank and system to ensure that old mold is dealt with, you might want to read the following recent thread:
http://www.airforums.com/forums/f443...er-166378.html
Adding a cup of bleach to the tank and other steps discussed in the thread above, will bring a less-than-perfect tank and system back up to speed. After a couple of hours you will need to flush the system and tank out well.
If you could post additional details, there are likely to be a variety of opinions and advice. Is your tank original from 1958?
Cheers,
Peter
PS -- Here are the search results, using the blue Google search box in blue above, for "water tank bleach," with other threads available --
https://www.google.com/search?q=wate...=airforums.com
Old 05-15-2017, 01:47 PM   #5
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
We drink the water from our Airstream tank so, as you might expect, we must make sure it is clean, safe and good tasting. I put a small amount ( 1/4 c or so) of clorox in our tank while on the way home on the last expected day on the road and let it slosh around for awhile. After getting home I flush it through the sink faucets and then open the drain to let it drain from the tank. Next time out I re-fill the tank with fresh water. I sometimes need to add water to the tank while on the road but always taste it first. If it doesn't pass my taste / smell test then no water until it does. We always keep a few bottles of water around just in case. So far this has worked for us.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 05-15-2017, 03:22 PM   #6
1979 23' Safari
Wayland , New York
It really depends on the water you're filing it with.
If the water going in is CG water that tastes bad to begin with there isn't much you can do but filter it either before or after the tank. CAMCO sells a inline filter that you can put on your hose to help filter the water before it goes into the tank and trailer. They also sell bottles of Drinking water freshener, it's a sodium hypochlorite bleach so it doesn't taste as bad as Clorox, it helps keep things from growing in the tank. I add it whenever I fill my tank. Both above are available at most wally worlds.
Another option is to set up a whole house water filter with activated carbon on the water hose feeding the trailer, then when you fill the tank use the hose going through the filter.
At the end of the year fill it with a bunch of water and bleach to shock clean the whole system before draining for winter.
Old 05-15-2017, 03:58 PM   #7
sgschwend's Avatar
1986 25' Sovereign
2008 F350, 6.4L diesel , Oak Harbor, WA
Images: 13
It also depends on the fill hose. It is best to have a hose used only to put water in, and then you drain it and store it in a safe place.
If you are getting that garden hose taste you will work very hard to remove it from your tank.
sgschwend is offline   Reply With Quote
Old 05-15-2017, 04:45 PM   #8
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
I keep my water tank full year around. Drain and refill every 30 days. I add a 1/4 of bleach. My trailer stays mostly prepped and ready to go quickly if necessary. All I need are consumables and clothes and I can be on the road in an hour. I keep enough gas on hand to go about 200 miles over what is in the tank. Living in a hurricane prone area my trailer is my escape pod.
MICHAEL
Old 05-15-2017, 04:51 PM   #9
Do you mean 1/4 cup of bleach?
Old 05-15-2017, 05:23 PM   #10
FCStreamer's Avatar
2014 30' Flying Cloud
I would never drink the water from my tank. I don't drink tap water either. YMMV.
2014 Airstream Flying Cloud 30 Recliner - WBCCI #4850 - AIR #110821
2018 Nissan Armada SL Tow Vehicle, Equal-i-zer Hitch
Visit Our Flying Cloud blog for my latest adventure!
FCStreamer is offline   Reply With Quote
Old 05-16-2017, 06:04 AM   #11
TheGreatleys's Avatar
1974 27' Overlander
Baltimore , Maryland
If you regularly add bleach and drink out of your tanks, you should consider at least a good carbon filter at the sink. Adding bleach will kill bacteria, but it can also produce some really nasty disinfection byproducts if there are organics in the water, like trihalomethane (THM) which is a carcinogen.
TheGreatleys is offline   Reply With Quote
Old 05-16-2017, 08:03 AM   #12
NWGetaways's Avatar
2012 22' FB Sport
2003 19' Bambi
Port Townsend , Washington
Same here. We have a Brita for drinking/coffee. I don't mind washing dishes or bodies, or boiling pasta or veggies with it, but I don't drink it.
NWGetaways is offline   Reply With Quote
Old 05-16-2017, 08:14 AM   #13
AWCHIEF's Avatar
Images: 33
Good heads up. Thank you. Yes, 1/4 cup of bleach.
MICHAEL
Old 05-16-2017, 08:45 AM   #14
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Question is. Do you want to drink live bugs or dead bugs?
?Best place to stay in Walla Walla for wine tasting?? Anders79 On The Road... 2 08-07-2016 09:20 PM
waste water tank and fresh water tank size 1964 safari jwmonty72 Waste Systems, Tanks & Totes 1 06-28-2016 04:21 PM
Wardrobe Doors - To Keep or Not To Keep? Rhino33 General Interior Topics 2 10-07-2015 03:34 PM
1959 Airstream Lounge Showroom -Tasting Room eBay Watch Airstreams on eBay 0 03-28-2011 12:00 PM
NEU 064 : Wine Tasting Rally AirHog WBCCI Rallies & Events 93 11-15-2005 09:12 AM
