Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Fresh Water Systems
Old 07-03-2004, 11:55 AM   #1
JeepinAudiophile's Avatar
1968 24' Tradewind
Fort Myers , Florida
Images: 66
Send a message via AIM to JeepinAudiophile Send a message via Yahoo to JeepinAudiophile
How to get plumbing out of inner skin
I have a 68' Tradewind, I am removing everything and the inner skin to re-wire and re-insulate. I have a pvc pipe that goes up the wall(curved) and then exits through the skin to a vent outside. How do i remove this without cutting the pipe (if possible)
Here's a link to see what i'm talking about. http://f2.pg.photos.yahoo.com/jeepinaudiophile
JeepinAudiophile is offline   Reply With Quote
Old 07-03-2004, 02:28 PM   #2
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Question ????
jeepin,
no picture at the link you posted. But it is no big deal to cut a "plastic" pipe and then when you are ready to replace it just use a coupler and the correct type of glue.
Aaron
WBCCI #XXXX AIR #2495
Old 07-03-2004, 04:21 PM   #3
LOST , Hawaii
Mine was flexible enough to bend and get out, it only went through the roof a couple of inches.
John
74Argosy24MH is offline   Reply With Quote
Old 07-03-2004, 04:29 PM   #4
Images: 59
In my (older) model, the vent pipe was polyethylene. Bends a lot easier to fit the curve of the roof. Would you consider replacing the PVC with polyethylene?
Old 07-04-2004, 01:10 PM   #5
1968 24' Tradewind
Images: 66
it may already be the polyethylene... it's pretty thin and seemingly flexible... Did it just pull downward out of the vent, or do i have to take the vent off from the outside and disassemble it from there?
Old 07-04-2004, 01:14 PM   #6
1968 24' Tradewind
Images: 66
http://us.f2.yahoofs.com/users/40b58...wtF6ABqRAyqtCz
http://us.f2.yahoofs.com/users/40b58...wtF6ABcohN3ujT
http://us.f2.yahoofs.com/users/40b58...wtF6ABf4XRF8p6
http://us.f2.yahoofs.com/users/40b58...wtF6ABPZyDqFGu
these should work... also to add... after thinking about it... i think it is PVC...
Old 07-04-2004, 01:36 PM   #7
LOST , Hawaii
I pulled down and it came out. OTOH, it would not be a bad idea to replace the gasket under the vent, they are one of the big leak sources. Take your choice.
John
Old 07-05-2004, 10:31 PM   #8
1968 24' Tradewind
Images: 66
woohoo!!! thanks all, argosy, you were right, it just pulled out... I had to cut it low on the straight so i could attatch it later then it just twisted and wiggled right out. 3 minutes later, i had the top panel of the inner skin off and out of the trailer. I can't believe how the mice get EVERYWHERE... I love this forum, thanks for all your suggestions.
Skin replacement Ken J Ribs, Skins & Rivets 292 05-29-2015 09:47 PM
Bringing a Plumbing System out of Long Term Storage 66Overlander Plumbing - Systems & Fixtures 5 05-18-2004 07:47 AM
plumbing pics for '77 Sovereign? maznblu Plumbing - Systems & Fixtures 3 04-14-2004 07:27 PM
Holding tank plumbing question yukionna 1997 - 2004 Bambi 15 09-10-2003 08:00 PM
Plumbing - A Mystery Pipe Tamara Plumbing - Systems & Fixtures 8 04-18-2003 12:56 PM
