Old 04-27-2014, 01:30 PM   #1
2012 22' FB Sport
Seattle , Washington
How to fill water tank?
I am new to my 22FB and trying to de-winterize. I can't seem to fill the water tank. Closed two drain valves under bed and two drain valves undter wardrobe. Opened faucet, hooked up water hose, turned on pump. Water heater seems to fill up, but not water tank (nothing coming out the drain valve if opened). Any help? Thanks.
ChrisnPatty is offline   Reply With Quote
Old 04-27-2014, 01:39 PM   #2
SteveH's Avatar
Common Sense , Texas
You cannot fill the water tank from the hose hook-up. You have to run the hose to the tank fill behind the little plastic door on the curb side.
Regards,
Steve
Old 04-27-2014, 01:41 PM   #3
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
If you "hooked up" your water hose, you're using the municipal water inlet, which bypasses the water tank. There's a separate tank fill nearby, that is larger than the hose so that air comes out the filler as water is going in. You can't "hook up" to it, you just stick the water hose in like you're filling a fuel tank at a gas pump.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 04-27-2014, 03:14 PM   #4
Mexray's Avatar
1978 28' Ambassador
Morada , California
Another pet-peeve...Why hasn't AS installed as standard, a 'tank fill' valve like the big buck Moho's that allow you to fill from the municipal inlet..???
I guess if one filled this way often, you could make a 'T' fitting (with a ball valve) and a length of hose just long enough to reach the tank fill opening that would attach to the municipal supply hose - of course, it's then another piece of 'stuff' to stow and haul around - downside...
Ray & Pat; Morada, CA
Old 04-27-2014, 04:15 PM   #5
Probably because it costs more. Not only do you need a new valve in the system, but your fresh tank vent has to be larger to make up for the fact that you're not letting air out the filler pipe anymore when water goes in.
That and if they did include a tank fill valve, someone else would come along and ask, "Why did Airstream do a dang fool thing like that? We liked it just the way it was!"
WBCCI #1105
TAC LA-4
Noobie - how to fill fresh water tank? Bohemian Fresh Water Systems 26 10-18-2016 01:51 PM
Remote water tank fill Garages Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 2 05-07-2010 11:36 PM
Fresh water tank fill jfowler218 Fresh Water Systems 4 04-21-2009 07:36 PM
Water Tank Fill Door Replacement Ganglin Fresh Water Systems 2 07-06-2007 07:13 AM
Can't fill water tank. Killo1 Fresh Water Systems 5 07-21-2006 10:28 PM
