Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Fresh Water Systems
Old 09-24-2011, 01:18 PM   #1
1977 21' Globetrotter
Davis , California
How to disassemble a drain valve
I have the standard red-handled drain valves in my Globetrotter.
The drain valve for the trailer fresh water system has a leak that causes a persistent drip at the outside drain tube, but also causes the water pump to cycle every couple of minutes.
I've removed the handle and the 13/16 nut that holds the stem packing, but I'm stumped about how to get the stem out. Basically, I'm afraid I'll damage the valve body.
There is a 1 1/2 hex shape at the top of the valve body, but it is either part of the valve body casting, or is frozen due to age.
Any suggestions about removing the stem would be greatly appreciated.
flyflinger is offline   Reply With Quote
Old 09-24-2011, 04:27 PM   #2
Splitrock's Avatar
Sioux Falls , South Dakota
Try this . . .
Old 09-25-2011, 11:17 PM   #3
Davis , California
Fixed the problem...needed a 1 5/32 inch wrench to remove the valve body. Thanks for the reply.
Fresh Water Tank Drain Valve greatlakes Fresh Water Systems 33 02-09-2023 11:02 AM
Freeing up water drain valve ashe Plumbing - Systems & Fixtures 8 09-10-2011 09:43 PM
Bad Check Valve in Pump??? tinbender Water Heaters, Filters & Pumps 3 06-16-2011 06:56 PM
Fresh Water Drain Valve Wrench withidl Fresh Water Systems 6 05-13-2011 07:31 PM
2008 Airstream Interstate Black Water Dump Valve Installed touching exhaust pipe!! solar-guy Sprinter and B-van Forum 0 05-09-2011 10:54 AM
