Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Fresh Water Systems
Old 10-22-2008, 04:22 PM   #1
2006 19' International CCD
Philadelphia , Pennsylvania
How to add chlorine to fresh water tank
ok, may be a silly question...
i see the sanitizing procedure in my manual for the 19' intl.
however, i can't find a cap on the top of the tank that would screw off to add this mixture.
i give up...what is the proper procedure?
thanks!
ericwarren is offline   Reply With Quote
Old 10-22-2008, 05:15 PM   #2
BDandTTs's Avatar
2005 22' International CCD
Phoenix , Arizona
Images: 49
Honest questions are never silly -- Start with the fresh water tank about half full. Dilute the required amount of bleach (~1/4 cup per 15 gallon capacity) in at least a gallon of water and pour it into the fresh water tank inlet on the outside of your trailer using a funnel and plastic tubing. You could also use a funnel inserted into the end of a filler like these offered at Camping World, Water Tank Fillers - Product - Camping World.
Make sure you use the fresh tank filler, not the city water hookup. Finish filling the fresh tank with water, and then use your pump to distribute it throughout your lines. Let it set for a few hours, dump, rinse, dump, and rinse again. Hopefully that will do it.
Bob, Dianne, and Tess the WFT
BDandTTs
Bandit #14576 (WDCU/AIR)
https://www.RWChatelain-Woodturner.com
BDandTTs is offline   Reply With Quote
Old 10-22-2008, 05:26 PM   #3
cammur's Avatar
Roseville , California
Curious about the need to dilute the chlorine before adding to the tank.
Cam
2005 25' Safari SS
2005 Dodge Ram 2500 Turbodiesel
WBCCI #3580 - Region 12 NorCal
AIR #8752
Roseville, CA
cammur is offline   Reply With Quote
Old 10-22-2008, 05:30 PM   #4
makes perfect sense....thanks!!!
Old 10-22-2008, 05:46 PM   #5
eubank's Avatar
Airstream - Other
Bosque Farms , New Mexico
When I do this, I go ahead and chlorinate the white hose as well. Pretty simple process: Pour the chlorine right down the hose; hook up the hose; fill the tank.
Lynn
ACI Big Red Number 21043
eubank is online now   Reply With Quote
Old 10-22-2008, 06:52 PM   #6
DEITZ645's Avatar
2006 30' Classic S/O
Mohrsville , Pennsylvania
Cam,
Safety. You don't want to get 100% chlorine bleach on too many things. It may be too caustic for the potable water tank and fill hose in a concetrated form.
Carl, Elaine & Finn The Beagle
2006 30' Classic W Slide & Limited Package Katarina
2006 GMC 2500 HD 6.6 Turbo Diesel Crew Cab 8' Bed
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
DEITZ645 is offline   Reply With Quote
Fresh water tank fills when hook up to city water Jonah On The Road... 17 09-24-2008 01:23 PM
Ratio of Fresh Water/Grey Water Tank, Help! erikjware Waste Systems, Tanks & Totes 1 05-08-2008 10:42 AM
Add Grey Water Tank to 1972 Trade Wind? AronS Waste Systems, Tanks & Totes 8 07-25-2007 07:43 AM
How much Chlorine to Sanitize a Fresh Water Holding Tank? Raptorrider2001 Fresh Water Systems 10 05-01-2006 03:04 PM
Can't find water leak - near fresh water tank. Loren Fresh Water Systems 16 01-01-2006 05:40 PM
