Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Fresh Water Systems
Old 09-14-2009, 07:54 AM   #1
Airdreamer
Dreamnair's Avatar
Profile:  1999 30' Excella 1000
Canyon Lake , Texas
How much water pressure is too much?
The water pressure in our AS is not impressive, although still functional. The shower is the biggest disappointment...it just kind of dribbles out (maybe this is intentional since the water heater capacity is only six gallons).
I have reason to believe that the Shureflo inlet valve for city water now on our trailer reduces incoming pressure to 40 psi. They now make the same valve for 65 psi. Can the AS piping take the higher pressure? Any reason not to change?
John
Dreamnair is offline   Reply With Quote
Old 09-14-2009, 08:14 AM   #2
moosetags's Avatar
Profile:  2005 25' Safari
Santa Rosa Beach , Florida
Is this a long term condition or one that has developed recently?
We had the same problem last year, and it turned out to be our in-line water filter was getting clogged with use and further restricting water pressure. We use one of those blue filters that hooks to the city water hose. We replaced the filter, and all was well again. We now carry a new back-up filter with us.
Brian
SuEllyn & Brian McCabe
WBCCI #3628 --- AIR #14872
2005 25' Safari FB (Lucy) with HAHA
2005 Suburban 2500 Quadrasteer (Olivia) & 2004 Suburban 2500 Quadrasteer (Daisy)
moosetags is online now   Reply With Quote
Old 09-14-2009, 08:23 AM   #3
RLS
RLS's Avatar
Profile:  2004 25' Classic
Longwood , Florida
We have the same problem. My filter is new and so is the pressure regulator. I just removed the regulator and all is good. I would guess my pressure reg. is not right. It drops the pressure down to about 25 psi! Maybe a pressure gauge connected some where would be a good idea?
RLS is offline   Reply With Quote
Old 09-14-2009, 08:31 AM   #4
moosetags's Avatar
I have also had that problem with the little brass pressure regulator becoming more and more restrictive. Replacing it did the trick. I now also carry an extra one of those.
Brian
Old 09-14-2009, 08:20 AM   #5
HowieE's Avatar
Profile:  1991 34' Excella
Princeton , New Jersey
Images: 11
I doubt if input pressure regulation is your problem.
First I would look at the screens on each of the faucets for dirt. Also the shower head should be removed and checked for dirt. To test if it is pressure or a supply problem just remove the kitchen faucet screen and turn the water on. If there is a significant difference clean the screen and then clean the others.
Raising the pressure of the regulator will only have an effect if the source pressure is above the set pressure of the regulator. I doubt you will see many systems that exceed 65 psi. The neighbors would be screaming because there washer machine control valves and hoses would be failing left and right
WBCCI 12156 AIR 3144 WDC unit
1997 6.5 Diesel Chevy 2500 See my pages mysite.verizon.net/vze54tx9/
and mysite.verizon.net/vze54tx9/kayak/
1991 34 ft. Excello +110,000 miles, new laminated flooring, new upholstery, new 3200 lbs axles
Old 09-14-2009, 08:50 AM   #6
azflycaster's Avatar
Profile:  1975 25' Tradewind
Phoenix , Arizona
Images: 62
John
Are you sure that the button on the shower head is not in dribble mode?
Richard
Charter Member Four Corners Unit
azflycaster is online now   Reply With Quote
Old 09-14-2009, 03:28 PM   #7
Airdreamer
Dreamnair's Avatar
Canyon Lake , Texas
Water Pressure Feedback
Thanks for the feedback. I know the screens at the faucet aren't the problem...they've both been replaced.
As for in-line filters, I'm not aware of any in the system (internal to the AS). Would appreciate comments to the contrary.
For RLS: Was your regulator built-in to your AS or external? Did you replace it or leave it out altogether?
John
Old 09-14-2009, 03:51 PM   #8
Alwhisman's Avatar
Profile:  1978 Argosy Minuet 7.3 Metre
Dayton , Texas
Images: 57
Send a message via Yahoo to Alwhisman
40 PSI is fine. I run mine at 27-33 psi. Has your shower head been replaced? If pressure seems lower there, you might just need to replace it with a low pressure/water saver style. They work on less water, thus, saving. A regular househould head would require too much water flow t get you where you want.
Mine was replaced before I got it, and the water kinda just fell out, lol. Instead of going original or RV, I got a water saver and it does well. I dont have the shutoff (dribble) like RV styles have.
Hope this helps
Al
Alwhisman is offline   Reply With Quote
Old 09-15-2009, 10:06 PM   #9
davidz71's Avatar
Profile:  1986 25' Sovereign
Southern Middle , Tennessee
Do you have a bypass system on your water heater? The lower cold water connection on mine has a tendency to allow sediment to back into the hose and eventually blocks it. I then have to disconnect it and run a coat hanger wire through the flexible braided hose to clean it out.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 09-15-2009, 11:40 PM   #10
RLS
RLS's Avatar
Longwood , Florida
I have the external one. Every time I try using it the wife yells to get rid of it when taking a shower! We also just got a new Oxygenics Body Spa Home/RV Showerhead that works great when not using the pressure regulator. So,as of now the pressure regulator is not being used, but you have me thinking about it and I guess it would be a good idea to go to the store and get a pressure gauge to hook up to the water line.
Old 09-17-2009, 07:16 AM   #11
Airdreamer
Dreamnair's Avatar
Canyon Lake , Texas
Getting some Power in the Shower
For Davidz71. Thanks, I'll take a look at the connections.
For RLS: Are you sure you don't have a pressure regulator at the city water entrance? Your unit is a few years younger, but I'd be surprised if they changed that valve in the meantime. If you do, it might be rated at 65 psi instead of 40. I'd still like to hear from someone as to whether the AS plumbing can take 65 psi. Did you get your showerhead at an RV dealer? Does it have an internal backflow valve of its own?
John
city water, inlet valve, pressure
Water Pressure tsunami Sinks, Showers & Toilets 2 04-30-2007 06:30 PM
Water Pressure Regulator & External Water Filter safarijim Off Topic Forum 7 02-01-2007 09:17 PM
water pressure starflyte1 Fresh Water Systems 5 11-14-2006 01:07 PM
No water pressure LI Pets Fresh Water Systems 13 09-21-2006 07:44 AM
water pressure or water pump? 59er Water Heaters, Filters & Pumps 3 07-01-2005 05:45 PM
