Old 07-31-2015, 05:41 PM   #1
johnamjr's Avatar
1970 25' Tradewind
parkville , Maryland
How do you keep your drain tubes clear of debris?
I keep getting mud and debris in my ac drain tube under my airstream. As well as my other drain tubes.
I have seen a contraption on commercial reefer trucks with tubes hanging under them but I don't know what it called. It looks like to flaps of rubber that clamp on the end of the tube and only let water out. And keep Denis out.
Does anyone know what I am talking about?
TIA
johnamjr is offline   Reply With Quote
Old 08-01-2015, 06:54 PM   #2
johnamjr's Avatar
1970 25' Tradewind
so they are called duckbill valves. Anyone ever use them?
TheSamba.com :: View topic - AC condensate drain tube tip and interior flooding
Old 08-01-2015, 08:33 PM   #3
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
I cut a 5' square of window screen then I folded the corners loosely around the end of the drain tube beneath the trailer (like a small purse) and used a hose clamp to hold it on. Have not had a blocked tube since.
When in storage I use a piece of fiberglass furnace filter inside the water heater and fridge doors to keep daubers out.
Alan
Spring in Air, Debris on New Vulkem eljay Leaks - Weatherstrips, Gaskets, Caulks & Sealants 10 04-11-2013 07:04 AM
Tell me I don't have to remove the skins please. AC drain tubes Taylormade Furnaces, Heaters, Fireplaces & Air Conditioning 10 05-20-2012 11:47 AM
drain tubes? bibbs Argosy Motorhomes 12 02-04-2007 06:56 AM
Where do you keep your bird when traveling? 68 Overlander The Pet Forum 3 05-19-2005 05:54 PM
Cleaning debris from roof? White roof? maxandgeorgia Cleaning, Stripping & Polishing 1 06-05-2004 09:59 PM
