Old 04-26-2012, 08:47 PM   #1
2008 27' International CCD FB
How do I drain fresh water holding tank?
I have a 27' International CCD and I cannot find the drain for the fresh water holding tank. The manual says that it is on the outside of the tank around the middle under the trailer but I cannot find the drain valve at all. Please help.
dgray is offline   Reply With Quote
Old 04-26-2012, 08:49 PM   #2
xo1rider's Avatar
2012 27' FB International
Fremont , California
On my 2012 International there are a couple of ways. on the left side behind the wheels there is a white colored valve that is a gravity drain. Just forward and toward the middle are two red handles. Turning both those red handles while turning on the water pump will quickly empty the fresh water.
"The bad news: there is no key to the universe.
The good news: it was never locked."
Swami Beyondananda
http://polakoff.com/RamblinRose/
Our travel log
xo1rider is offline   Reply With Quote
Old 04-26-2012, 08:50 PM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
It should be a small white plastic T handle valve just inside the passenger side wheels.
2004 Excursion 4x4
Old 04-26-2012, 09:00 PM   #4
kds
2008 27' Safari FB SE
Frederickburg , Texas
I have a 2008 27 FB and mine is like HowieE's. Good luck.
kds is offline   Reply With Quote
Old 04-26-2012, 11:56 PM   #5
SuperTrouper's Avatar
Petaluma , California
Here's a post that covers it. It's a half a turn to open and it's located between the wheels on the street side.
http://www.airforums.com/forums/f443...nch-77246.html
I have a 2008 27FB and I slotted a small aluminum tube (an el-cheapo giveaway AAA flashlight) as a tool to open and close the valve. The valve handle is on top of the fitting. If it's tight be very careful not to break the valve if you use a tool.
brad
SuperTrouper is offline   Reply With Quote
Old 04-27-2012, 12:05 AM   #6
And another thread:
http://www.airforums.com/forums/show...ferrerid=55387
Old 04-27-2012, 06:36 AM   #7
Thanks for all of your help. I just hope it doesn't break off
Old 04-27-2012, 06:46 AM   #8
ZoominC6's Avatar
2004 30' Classic Slideout
Colleyville , Texas
I have a confession.....We've owned ours since new in '04 and I always opened the pitcock valves on the bottom of the water tank and turned on the pump to drain the tank.
This year our Airstream was dropped off at our dealer's shop in a snowstorm so that he could change out our pump. When the trailer was returned I could not keep water in the tank when filling and found the source of the problem was the gravity drain opened by the dealer to winterize the trailer. I found it on the passenger side and hard to get to near the front wheel. How embarassing!
In dog years, I'm dead!
ZoominC6 is offline   Reply With Quote
Old 04-27-2012, 07:05 AM   #9
Dan@LED4RV's Avatar
Denton , North Carolina
silicon spray
If you have the white one that is plastic you can use a silicon spray with a small red plastic straw and direct the spray at the top of the turning handle. Some times this makes it easy to turn.
If it were to break, it can be a big hassle to replace. The part does not cost very much but getting to it (dropping the pan) can be pricy if your having someone else do it and allot of work for you if your doing it.
As a rule of thumb (for anyone else following this thread) if the unit is more than 3 or 4 years old and you have to drop the belly pan I would always replace the plastic drain.
Dan Brown
Denton NC
Dan@LED4RV is offline   Reply With Quote
