Old 08-02-2016, 12:57 PM   #1
2012 25' FB Flying Cloud
College Station , Texas
Hole in fresh water tank
My Wife and I are first time owners. During preparation for our first trip I noticed a leak, curb side, in the fresh water tank. The leak emanates from what appears to be a hole, perhaps one eighth inch in diameter, on the tank bottom directly between the curb side wheels.
Is this intended to be a drain hole from which a plug has been removed or a defect or damage?
Assistance is much appreciated.
TheFishFam is offline   Reply With Quote
Old 08-02-2016, 01:06 PM   #2
richw46's Avatar
Lexington , Kentucky
That's one of the places where the drain plug/spigot is usually found. On mine there is a small metal piece that the water hits on the way down. Do you see something like that below the leak? Sounds like yours may be missing.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE
richw46 is offline   Reply With Quote
Old 08-02-2016, 01:15 PM   #3
Thanks for the reply. We have one of those spigots on the street side. Is there one on the curb side also?
Old 08-02-2016, 01:28 PM   #4
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
If your water tank is like my 2008 then the water tank has a Rotocast cover. The actual water tank is supported by this cover and Styrofoam blocks inside. The water drain exits the tank to the street side outside valve with a short tube. To replace that tube you would have to cut an access hatch in the bottom of the Rotacast lining.
The holes in the Rotocast shell is to allow any water to drain from within the shell. I had a small water leak from a connection above the floor hole where pipes come up from the tank. Water collected in the shell and it dripped out from one of the middle holes. I was worried I had a leaking water tank but after repairing the connection above the problem was solved. I also noticed the water pump would cycle on/off after about an hour indicating a plumbing leak.
Since your description indicates leaking from the curb side its either the water tank leaks, the water fill hose may not be tight and when filling the tank water gets into the shell or the water drain hose is leaking and somehow in the shell its leaking out the curb side drain holes. I would think the 2013 25fb modes still have the drain on the street side between the wheels but may the water is still drain via the curb side.
Kelvin
Old 09-21-2016, 08:45 PM   #5
drew05's Avatar
2011 25' FB Flying Cloud
Peculiar , Missouri
I have a similar issue. My leak just started to occur on the curb side holes, after sitting for about 3-4 weeks. The drip is a slow drip. My trailer sits low to the curb side. I'll take a look this weekend --- weather dependent...
Drew
drew05 is offline   Reply With Quote
waste water tank and fresh water tank size 1964 safari jwmonty72 Waste Systems, Tanks & Totes 1 06-28-2016 05:21 PM
Making sure Fresh Water Tank is 'fresh'? ATE123 Sprinter and B-van Forum 15 07-21-2015 09:51 PM
Water heater tank hole repair at fitting: weld? rippie Water Heaters, Filters & Pumps 5 01-29-2014 05:02 PM
Fresh Water Tank Leak At Bottom of Tank From 1/8" Hole KJRitchie Fresh Water Systems 25 06-25-2013 09:25 AM
Drilled a hole in water tank, HELP bmklawt Fresh Water Systems 18 07-12-2009 11:00 PM
