Old 04-13-2010, 03:58 PM   #1
1976 Argosy 24
Toronto , Ontario
Holding Tank to Water Pump Question..One 'small' step
I'd like to replace the plumbing with Pex pipe and the PO seems to have disconnected the plumbing. I would only like to go as far as from the holding tank to the water pump this weekend..(one small step at a time) Is the attached pdf sketch correct? I've shown a bypass for the water pump..do I need it? Are the shut off valves shown in the correct place? Thank you in advance, if you have time to reply. There is a pdf attached and an image of the existing situation.
MikeDT is offline   Reply With Quote
Old 04-13-2010, 04:41 PM   #2
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
Where does the city water come into your diagram?
Michelle TAC MT-0
Sarah, Snowball
Old 04-13-2010, 05:01 PM   #3
1976 Argosy 24
Toronto , Ontario
Hi Michelle,There is a city water inlet on the opposite end of the trailer, and water inlet on the holding tank side of the trailer. I focused the diagram on the items between the holding tank and the pump, and didn't show the inlet on the holding tank.
Old 04-13-2010, 05:23 PM   #4
HowieE's Avatar
Princeton , New Jersey
Images: 12
I think there is a problem with your diagram.
There should be a suction line directly from the tank to the pump. The output of the pump should tie, TEE, into the trailer water system.
If your only access to the tank is at the drain, rather than a separate line to the bottom of the tank entering at the top, you can use it but you want to be sure the drain cock will not allow air into the suction side of the pump.
I can't see any reason fore the bypass you have drawn around the pump.
2004 Excursion 4x4
Old 04-13-2010, 05:35 PM   #5
1976 Argosy 24
Toronto , Ontario
Thanks..I'll go back to the drawing board. I've been having a hard time finding a basic plumbing plan, or plumbing 101..does anyone know of one?
Old 04-13-2010, 07:03 PM   #6
1976 25' Caravanner
Campton , New Hampshire
On my '76 the suction line comes off the bottom of the tank . I installed a T with a drain valve and a sreened filter before entering the inlet of the pump . The suction line is hose with clamps . From the pump outlet it T's into the cold water line . I also installed a shut off in this hose. The reason for the shut off is to ease the strain on the pump . Technically the pump will stop the city water from going into the holding tank but they sometimes do not , depending on the pressure . Those are the only two valves involved. Be sure the suction hose is stiff enough for suction or it will crush with the pump going. Good luck
ticki2 is offline   Reply With Quote
Old 04-14-2010, 08:15 AM   #7
Keymar , Maryland
I installed one to fill my water tank off city water. no sticking the hose in the hole and holding it. I just don't know why he has one.
Michelle TAC MT-0
Sarah, Snowball
Old 04-14-2010, 08:55 AM   #8
HowieE's Avatar
Images: 12
Great idea. If we can assume the Xs on the drawing are valves there is no reason for them at other than the drain and in the bypass.
2004 Excursion 4x4
Old 04-14-2010, 11:17 AM   #9
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
I'm working on the same project. Mine also has the bypass to fill the tank from city water, which is original to the trailer.
I think you might have more shut off valves than necessary in your plan. Mine only has three in the area of the pump. Below is a picture of the system in that area.
One valve is the drain to ground for that whole front section of the water system, including the tank. That is the upper red knob in the picture.
One is between the pump and the tank (the blue knob).
One is between the water system and the pump inlet. The lower red knob.
I'm planning to replumb without the city water bypass, since we always use the fresh water tank.
Stephanie
Old 04-15-2010, 09:42 AM   #10
1976 Argosy 24
Toronto , Ontario
Awesome
Thank you Stephanie, Thats a great clarification and explanation. The image is a great help too! I'm on the verge of 'getting it'.
Old 04-15-2010, 09:47 AM   #11
blickcd's Avatar
Milford , Ohio
While you are in there, I suggest installing a three-way valve at the connection to the tank for easy winterizing. There is a kit available for that which comes with the valve, and some 3/8" tubing off the tee so you can pull the antifreeze right from the jug as opposed to dumping it in your tank.
Christopher
blickcd is offline   Reply With Quote
Old 04-15-2010, 10:32 AM   #12
1976 Argosy 24
Toronto , Ontario
antifreeze to bypass the holding tank?
Hi Christopher,
I haven't winterized yet..since this is my first month having the trailer. Does antifreeze also stay in the holding tank over winter, or does it get by passed? If there is no need for antifreeze in the holding tank, that sounds like a good idea to install this tee, to let antifreeze into the system and bypass the holding tank. I hope I'm understanding correctly.
Thanks.
Mike.
Old 04-16-2010, 01:34 PM   #13
hampstead38's Avatar
1967 26' Overlander
Upperco , Maryland
My plumbing design is to fill the fresh water tank using the existing fill tube. I also plan to have backflow prevention or "check" valves on the shore water fill line and downstream of the water tank. In my experience, plumbing codes require a check valve on connnections to public water. I suppose you could accomplish the same general purpose with a wheel or ball valve downstream of the water tank, but I would inevitably forget to close it... and pressure test my fill cap.
hampstead38 is offline   Reply With Quote
Old 05-05-2010, 07:02 PM   #14
1976 Argosy 24
Toronto , Ontario
I did it!
Thank you..I've connected the pump to the holding tank, and the plumbing to the kitchen is in place..I'll have it running this weekend. I'll post pictures on my introduction thread. Thanks for all the advice. It has all been very helpful...Trailer Life!
Holding Tank Question airboy1 1974 - 1979 Ambassador 3 08-14-2006 07:29 PM
Fresh Water Holding Tank Question... JWest Fresh Water Systems 4 05-08-2004 06:53 AM
holding tank question.. Morning Dew Waste Systems, Tanks & Totes 1 03-19-2004 03:44 PM
Holding tank plumbing question yukionna 1997 - 2004 Bambi 15 09-10-2003 08:00 PM
Holding tank Question GOTPIKE All Argosy Trailers 4 08-20-2003 09:35 AM
