Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Fresh Water Systems
Prev Previous Post   Next Post Next
Old 09-03-2009, 12:26 PM   #1
Profile:  1976 31' Sovereign
Missouri City , Texas
High pressure water supply
We are staying a RV park in San Antonio and the water pressure at the park at each site is 110 PSI +. They do warn you as you check in to be sure to use a hose end pressure regulator at the water valve to protect your water lines and hose. So I pulled out my trusty brass hose end water regulator and screwed it onto the water valve and then hooked everything up. My water regulator has a small gauge and it indicated that I was at the preset 50 psi and everything worked fine until around 10:30 pm when I heard a noise around the bath area like running water. I went out side with a flash light and found water running out at the bottom of the hot water heater door and when I looked at the gauge on the regulator it showed over 100 psi. I turned off the water and opened the water heater door and found that the pressure regulator on the water heater had tripped. It is set at 100 psi. I bought a new hose end regulator this morning and I am back to 50 psi. I was surprised that my old regulator failed but I guess nothing last forever. Or maybe these things will fail if the pressure gets to high, 110 psi plus. I have never stayed in a part with water pressure this high. I just hope the new one holds up for a few days. I plan on turning off the water at the valve when we are gone and at night.
Don
adonh is offline   Reply With Quote
High Pressure vs. Low pressure Appliances emenriquez General Appliance Topics 2 06-15-2009 02:04 AM
High oil pressure indicated on gauges Mr. D Mechanics Corner - Engines, Transmission & More... 11 11-02-2006 12:28 PM
Water supply problem 1970 Overlander TroutStream Fresh Water Systems 5 06-10-2004 03:53 PM
water supply crimp ring Lido&Linda Airstream Motorhome Forums 6 10-23-2003 07:58 PM
Low pressure / High pressure appliances Rick LP Gas, Piping, Tanks & Regulators 1 06-15-2002 07:29 PM
