Old 05-15-2011, 07:14 AM   #1
Michigander's Avatar
2005 30' Land Yacht 30 SL
Oakland County , Michigan
Hidden Plumbing Dead-End!!
Well, we opened the MH yesterday, hallelujah!
Later in the evening, my DW and I were sitting on the sofa, enjoying a beverage, and discussing storage space. She looked at the drawer under the fridge and said she wished it were larger.
So, being the dutiful and handy husband that I am, I pulled the drawer out to see if there was any space behind it in case I wanted to enlarge it.
Lo and behold, below is what I discovered. Not only was there room at the back for expansion, but I discovered plumbing that I did not know existed.
I'm pretty sure that, because it's under the fridge, it is a feed to an icemaker, which I do not have.
What concerns me is that for the past four years, I have faithfully winterized my plumbing without knowledge of this 4-5 foot dead end. If you look closely at the photo, the PEX tubing has a pink cast to it as it trails off to the right. I'm pretty sure this is leftover antifreeze that did not flush out.
Probably, the pink stuff will dilute over the course of the summer, but now that I know about this dead end, I'll always wonder when winterizing in the fall if I got enough pink fluid back into the system to cover this area.
Maybe I'll install a valve closer to the take-off. What a pain in the butt!!
I know igorance can be bliss, but the potential for a disastrous plumbing leak makes me worry. Any suggestions out there?
Bob & Nancy
2005 ASLYG 30 SO
2009 Wrangler Toad
Michigan
Michigander is offline   Reply With Quote
Old 05-15-2011, 07:58 AM   #2
Airstreamer67's Avatar
Your concerns are good ones. That is a freeze-damage point waiting to happen.
I would put a valve on the end, and open it with a connected drain hose to get antifreeze or compressed air in there during the winter preparation process.
Airstreamer67 is offline   Reply With Quote
Old 05-15-2011, 08:22 AM   #3
I'm with you. I cannot just let it stay as is and hope for the best. I've been lucky so far but don't want to push it. Thanks for your input.
Bob & Nancy
2005 ASLYG 30 SO
2009 Wrangler Toad
Michigan
Old 05-15-2011, 10:07 AM   #4
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
I have a separate ice maker next to the refer. When I winterize I disconnect the water supply to make sure everything is drained. I'm not sure about your coach but on mine the water tank is under the couch behind the drivers seat. The water starts there and makes a loop to the rear bath and up the right side to the ice maker. If I don't drain the ice maker, that is probably 8' or 10' of tubing to freeze.
Cheers, Dan
Rear End Separation Permanent Fix? dmand001 Repairing/Replacing Floor &/or Frame 23 07-24-2017 02:12 PM
How does my rear end look? desertair27 Repairing/Replacing Floor &/or Frame 35 02-23-2013 11:24 PM
Some insight on how things end up the way they are Boondocker WBCCI Forum 24 04-26-2011 08:06 PM
Before I remove bath end cap Breadbug Ribs, Skins & Rivets 3 01-27-2011 01:03 PM
