Old 07-16-2006, 08:59 AM   #1
Help with Filling Water Tank
We are getting ready to take our '73 O'Lander out for the first time since we purchased it last year. I checked everything out when we brought it home and everything checked out fine. I winterized it and now seem to have issues with filling the water tank with the city water connection. All 5 drain valves are closed (the 2 in the back roadside compartment and the 3 under the sink). When I turn the city water on to fill and pressurize, the water just runs out of the back drain tube. What gives? Any help would be appreciated. Those valves are so confusing.
James
james814 is offline   Reply With Quote
Old 07-16-2006, 09:13 AM   #2
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
well...first of all, with the "stock" configuration, you can't fill the water tank with the city water connection. You fill it through the water filler spout.
with the city water connected and all the valves closed, the city water pressure will simply pressurize the pipes. (there's a check-valve that prevents water from getting into the tank; the pump can pressurize the lines from the other end, but water can't flow back toward the tank. there's a check-valve on the other end of the system, as well, just before the city water inlet, that keeps pumped water from going out there). If water is coming out the back drain, either the valve is actually open, or the pressure relief valve is stuck open...or not "stuck" and doing its job of relieving excessive line pressure...which would mean that your on-board regulator isn't doing its job.
you'll have to figure out which drain tube its coming out of; look under the back, and you should see 2. Then go look under the bathroom sink and see if you can deterimine if its the drain valve, or relief.
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Water Heater Craig 1978- 1979 Excella 500 7 10-01-2007 05:16 PM
No Grey Water Tank????? Anna Waste Systems, Tanks & Totes 16 11-17-2002 07:33 PM
1978 Minuet 6.0 Metre Gray Water Tank overlander64 All Argosy Trailers 6 11-15-2002 06:11 AM
Pressurized water tank eracism Fresh Water Systems 2 10-25-2002 06:09 AM
Replacing Black Water Tank Tamara Waste Systems, Tanks & Totes 15 06-18-2002 10:45 PM
