Old 04-29-2012, 04:58 PM   #1
RAG
RAG's Avatar
2004 30' Land Yacht Gas 30
Canadensis , Pennsylvania
Help with a Fresh Water Plumbing Problem…
2004 Land Yacht 30 MoHo
When dry camping, if I turn on the water pump, water from the fresh water tank is forcefully blown out the exterior city water hose input connection, therefore, the system never pressurizes and the pump continues to run; strange, but true. I’d estimate, 25% of the water pressure from the pump is available to the faucets and 75% exits the motorhome through the city water connection. This is great if your purpose is to water the campground , but undesirable if a shower is the intention.
When hooked-up to city water, all is well; no problems.
Any and all help would be greatly appreciated…….
ID:	157056   Click image for larger version
RAG is offline   Reply With Quote
Old 04-29-2012, 05:14 PM   #2
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
You either have a bad check valve or you have the city water valve open. Follow the city water line from where it enters the MH. The may be a valve that has a handle on it much like the one you connect the garden hose at home. It should not be far from where it comes into the MH. In a pinch, just cap the city water connection off.
Old 04-29-2012, 06:28 PM   #3
RAG
RAG's Avatar
Don't think there's a City Water Shut Off Valve anywhere and I don't see a check valve. Here's a close-up photo with some labels. Does this help?
Old 04-29-2012, 06:54 PM   #4
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Looks like something was missed in the plumbing. I don't see a check valve or manual shut off. It may be built into the regulator. It looks like a manual shut off could be installed relatively easy.
Old 04-29-2012, 09:20 PM   #5
Globestream's Avatar
1964 19' Globetrotter
1961 22' Spaceliner
Springville , Utah
I agree with TG, there is no check valve seen in this pic. I wonder if the only check valve in your system is right where you connect to city water. I just bought a new city water female connector, and it has a little steel ball inside of it that act as a check valve. If that is the only check valve in your system, is it possible that yours has seized itself in the open position? Have you been connected to a water source that was dirty, or even just hard water? Maybe see if you can dislodge that little steel ball ( if you have one), or like TG says it would be easy to install a check valve (or manual).
Ben
Globestream
1964 Globetrotter
1961 Spaceliner
Utah
Globestream is offline   Reply With Quote
Old 04-29-2012, 09:32 PM   #6
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
Atlanta Burbs , Georgia
Even if you add a check valve, your city water pressure valve isn't working properly. I'd replace it.
SeeMore is offline   Reply With Quote
Old 04-29-2012, 09:34 PM   #7
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Another thought is if the city water pressure is high. It could jam the check valve open.
Also if the pump is not creating enough pressure/ flow to free the jammed check.
Old 04-29-2012, 09:46 PM   #8
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
I'm not sure the pressure regulator is bad. I think I read that all is well on city water.
But I'm not sure pressure regulators are designed for water to flow in the reverse direction.
I would install a manual valve down stream from the pressure regulator. No guessing, when it's closed it's closed.
Old 04-29-2012, 09:47 PM   #9
RAG
RAG's Avatar
Do pressure regulators work both ways or only coming in from city water connections?
Old 04-29-2012, 09:51 PM   #10
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
One way, for city water. The pump has a pressure switch, usually around 40 psi which prevents excess pressure from the pump. A pressure regulator on the pump side is not necessary.
Old 04-29-2012, 09:55 PM   #11
RAG
RAG's Avatar
The factory set on the pump is supposedly 65psi, but can the pressure from the pump back feed water through the in-line regulator?
Old 04-29-2012, 09:55 PM   #12
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Try this, connect the hose to the MH. Disconnect it from the source. Fold it over like you would to prevent the water from coming out. Then start the pump to see what happens.
Old 04-29-2012, 10:00 PM   #13
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
If there is not a check valve or manual valve between the pump and the regulator, the water will flow to the regulator when the pump is on. That's why it's running out the connection for the city water. If there is one at the hose connection, it is not working if water is coming out where you hook the hose up.
Old 04-29-2012, 10:05 PM   #14
RAG
RAG's Avatar
Makes sense. Well, tomorrow morning will tell.....
Thanks TG!
