Old 09-06-2014, 08:43 AM   #1
2014 27' Flying Cloud
2007 23' Safari SE
1973 23' Safari
Roanoke , Virginia
help w/ tnk drain
I have a 2007 safari 23 ft and have never used the water tank (owned 2 years),I need to boondock next week and the drain plug is "frozen" open. since it is plastic i don't want to torque too hard. Is there a way to take it out easily?or anything else . thanks
catec is offline   Reply With Quote
Old 09-06-2014, 08:50 AM   #2
Gainesville , Florida
Try pushing on it slightly and turning clockwise. Jim
Old 09-06-2014, 09:00 AM   #3
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
The probable Chinese producer of those valves at that time made them too tight. I needed a pliers to turn mine when new, and it never got better. Surprised it didn't break. The newer ones seem to be better. Try some penetrating lube or silicon spray on it.
Doug and Cheryl
Old 09-06-2014, 10:32 AM   #4
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
My Safari's drain valve has to make a half turn, from open to close. I cannot turn it using my fingers, so I made a wrench for the tank drain valve. I cut a 1/4" x 3/4" aluminum bar about 5" to 6" long, short enough to rotate the valve in the limited space but long enough for me to get a grip. I cut a slot centered in one end of the bar, the length x width to match thumb turn on the valve. Now it is easy to turn, using the wrench. But it's still hard to reach it behind the wheel.
Alan
Old 09-06-2014, 11:37 AM   #5
HowieE's Avatar
Princeton , New Jersey
Images: 12
if you are talking about the fresh water holding tank and not the water system drains I did this. I took a 3/16 x 2 in. eye bolt and hammered the eye to just fit over the Tee handle. Remove the tire and with vise grip close the eye on the Tee handle. Now I can reach behind the tire and easily open or close the valve with this handle.
If your valve is currently open make sure you position the Tee so you can close the valve once installed because it would be hard to change once on.
2004 Excursion 4x4
Old 09-06-2014, 12:04 PM   #6
Home of Vortex tuning
CDONA's Avatar
2013 27' FB Eddie Bauer
Spearfish , South Dakota
For a quick fix, fit a suitable hose over the open end, make it removable yet secure, and plug it.
"Chip Tank" is in Flagstaff Az.
CDONA is offline   Reply With Quote
Old 09-06-2014, 07:52 PM   #7
2007 23' Safari SE
1973 23' Safari
Roanoke , Virginia
got it closed thanks for the suggestions
under the box though there is another petcock in the metal box. is that for leaks and condensation or something else.
Re working kitchen drain- pex for drain lines?? Bwilson11 General Repair Forum 4 04-20-2014 08:42 PM
fresh water drain: broke it off. help jparks Fresh Water Systems 12 10-07-2009 06:20 PM
A/C Drain ...leaking at drain hose connection Sav'h Steve Furnaces, Heaters, Fireplaces & Air Conditioning 5 08-01-2004 04:09 PM
water drain valve leaking - help! wayner1239 Fresh Water Systems 14 02-01-2004 04:10 PM
water drain valve leaking - help! wayner1239 Waste Systems, Tanks & Totes 0 01-31-2004 10:03 AM
