Old 08-26-2016, 03:28 PM   #1
PSU1981
2015 27' Flying Cloud
Spring , Texas
Help - trying to put bleach in fresh water tank
I have a 2015 27FB FC that I am trying to clean fresh water tank with a little bleach. Can't figure how to get bleach in FW tank without spilling it?
PSU1981 is offline   Reply With Quote
Old 08-26-2016, 03:32 PM   #2
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
Use a dedicated funnel. Do not reuse for any other chemicals.
Find at hardware or big box store probably like for adding engine oil with a bend in the bottom part so it can be nearly vertical while the tip is in the tank.
Old 08-26-2016, 03:36 PM   #3
2008 27' Safari FB SE
Long Beach , California
A water bottle will also work. The standard bottled water bottle, that is, as in a Dasani, Aquafina, Crystal Geyser, etc.
I filled it with the proper amount of bleach, added some water, mixed it and poured it into the opening. The mouth of the bottle should fit perfectly into the fresh water filler opening.
LBOskiBear is offline   Reply With Quote
Old 08-26-2016, 03:51 PM   #4
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
I have a dedicated small long neck blue plastic funnel for the water tank. The neck is about 10 inches long. Available from wallyworld.
MICHAEL
Old 08-26-2016, 04:23 PM   #5
PSU1981
Spring , Texas
Figured it out - been a few months - hot here in TX - heat must have got to my brain.
Thanks everyone!!
Old 08-26-2016, 04:46 PM   #6
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
I find water bottlees are good for it too.
I always make sure though that when I carry bleach in a water bottle, I clearly mark the bottle "Bleach - don't drink!" with a sharpie!
Otherwise, with my luck, it would happen!
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 08-26-2016, 05:19 PM   #7
Normal , Illinois
Rather than mess with pouring liquid bleach, you can buy bleach tablets in that section of your grocer or WalMart.
Just drop a couple in a half tank or so of water, sanitize as usual.
Maggie
Old 08-27-2016, 11:48 AM   #8
Ahab's Avatar
2008 22' Safari
Oracle , Arizona
I use a plastic Turkey Baster. Comes in handy for adding distilled water to your batteries too.
Ahab is offline   Reply With Quote
Old 08-27-2016, 12:39 PM   #9
2015 30' International
FREDERICK , Maryland
That is what I do, then recycle the bottle
Doc Foster is offline   Reply With Quote
Old 08-27-2016, 01:16 PM   #10
Larry C's Avatar
1996 34' Excella
Elberta , Alabama
Simple, just use a measuring cup, and pour it into the hose before you turn onthe water to fill the tank...
For whatever it's worth
Larry
Old age is coming at a really bad time!
1996 34' Excella 1000, interior totally redone, 2003 Dodge/Cummins HO, U.S. Gear exhaust brake, Diablo tuner, 115 gallon aux fuel, Bedslide, Airsafe/Reese Dual Cam, and a bunch of other stuff
Larry C is offline   Reply With Quote
Old 08-27-2016, 01:33 PM   #11
2006 22' Parkway
Poughkeepsie , New York
I cut the bottom out of a plastic water bottle and could pour the bleach in that end and then was able to squeeze and bend the bottle enough for the bleach to flow through.
Skerr is offline   Reply With Quote
Old 08-27-2016, 02:00 PM   #12
greghoro's Avatar
2013 25' Flying Cloud
Wheaton , Illinois
This is the best funnel I have found for filling the fresh water tank: http://www.lubeq.com/products/02562
Amazon sells it but it is quite pricey when shipping is included.
The spout unscrews from the body and you can store both in a 1 gallon zip-lock bag. This is a big funnel with great flow.
You need to remove the down-turned bill as well as trim a bit of the spout to fit your intake.
When trimmed properly, the spout fits nice and snug in the tank intake to make it free standing. This allows me to use both hands to heft up a 5 gallon Coleman camping jug and pour it in without needing a second person to steady the funnel.
Also comes with the metal filter screen to keep those pesky bugs from going down the drain as they inevitably swarm around you when your hands are tied up.
Greg
greghoro is offline   Reply With Quote
Old 08-27-2016, 03:27 PM   #13
Riverdrifter's Avatar
2012 30' International
Ferndale , Washington
I use a long spout watering can. Pour the right amount of bleach in and fill with water so you aren't pouring full strength bleach in (can get your clothes!) Works great for me!
Riverdrifter is offline   Reply With Quote
Old 08-27-2016, 06:46 PM   #14
2007 25' Classic
Hutto , Texas
I use the fresh water hose that I will use to fill the tank after the bleach is put in. Empty the water from the hose if there is any in it. Hook the hose to the water supply but don't turn it on.
Pour the bleach into the end of the hose where the water will come out. Then put that end of the hose into the tank fill port. Turn on the water.
The fresh water will flush the bleach into the tank and by the time the tank is full of water, the hose will be totally rinsed.
Wanderer2604 is offline   Reply With Quote
Store with bleach in tank and lines? KYAirstream Fresh Water Systems 16 07-19-2014 12:47 PM
Where do I add bleach to the fresh water system? lrw Fresh Water Systems 18 09-28-2013 03:07 PM
Do you sanitize hot water tank with bleach? bonginator Fresh Water Systems 2 05-14-2013 05:06 PM
How do you pour bleach into freshwater tank ? dgmelp Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 19 10-29-2012 06:52 AM
Sanitize Black Water Tank with Bleach Air-Texas Waste Systems, Tanks & Totes 47 12-03-2011 05:54 PM
