Old 08-28-2016, 05:39 PM   #15
Stay CazuaL
cazual6's Avatar
2014 19' Flying Cloud
Reseda , California
Here are some reference for you for sanitizing: 1 tablespoon per 1 gallon.
1 tablespoon = 0.5 oz.
So for my 22 gallon fresh tank, I need 11 ounces of bleach.
"No job is so simple that it cannot be done wrong."
"Everyone is entitled to be stupid, but some abuse the privilege."
"Either I will find a way, or I will make one."
"Sweat is your fat crying"
WBCCI 9164
cazual6 is offline   Reply With Quote
Old 08-28-2016, 06:56 PM   #16
1976 31' Sovereign
Oswego , Illinois
1976 AS has drop down door for water fill so very easy to fill and add bleach. I measure bleach in measuring cup, pour in imed. put hose in to flush down and fill tank. I don't mix water and bleach. I have done this way for yrs. no bottles or funnels
Old 08-28-2016, 07:38 PM   #17
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Why not sanitize the hoses at the same time?
I connect all of my water hoses together then flush them with fresh water.
Then I disconnect from the hose bib and drain the hose onto the ground, not into the tank.
Then I put one end into the tank filler tube, then pour in the appropriate quantity of bleach into the hose just before connecting it to the hose bib. Full strength bleach goes through the hose as it goes toward the tank.
I've been doing it this way for 20+years.
Alan
Old 08-30-2016, 05:35 PM   #18
1976 31' Sovereign
Oswego , Illinois
Why not pour strait bleach into tank and have hose turned on to imed. fill with water? I have done this way for 39 yrs. w/out any prob. or harm.Only dif. is 1976 AS has drop down door so no delay hooking up hose. Bleach won't harm out side if spilled as I mix 1/2 bleach 1/2 water in spray bottle to spray mold that grows panels upper and lower belt line on rear and rear sides then wash trailer. Bill
Old 08-31-2016, 08:49 AM   #19
PSU1981
2015 27' Flying Cloud
Spring , Texas
Question - I like the idea of putting bleach directly in the hose except I would think you would have to remove the in line H2O filter 1st & then put back on before going into FW tank?
PSU1981 is offline   Reply With Quote
Old 08-31-2016, 08:54 AM   #20
Lily&Me's Avatar
Normal , Illinois
Straight, undiluted, bleach might damage your hose, and certainly your water filter.
Dropping a bleach tablet or two in thru the fresh water fill works great.
No muss, no fuss.
Maggie
Lily&Me is online now   Reply With Quote
Store with bleach in tank and lines? KYAirstream Fresh Water Systems 16 07-19-2014 01:47 PM
Where do I add bleach to the fresh water system? lrw Fresh Water Systems 18 09-28-2013 04:07 PM
Do you sanitize hot water tank with bleach? bonginator Fresh Water Systems 2 05-14-2013 06:06 PM
How do you pour bleach into freshwater tank ? dgmelp Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 19 10-29-2012 07:52 AM
Sanitize Black Water Tank with Bleach Air-Texas Waste Systems, Tanks & Totes 47 12-03-2011 06:54 PM
