Old 06-13-2009, 08:09 AM   #1
2002 19' Bambi
Boulder , Colorado
Help: Shower and Toilet work; No water pressure in sinks
I hooked up to water at an RV Park. All looks normal except neither sink (kitchen or bath) have water pressure. The shower and toilet work fine.
What's up?
donshade is offline   Reply With Quote
Old 06-13-2009, 08:25 AM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Have you used the trailer since you de-winterized it? You may have a couple of valves in the wrong position.
Old 06-13-2009, 08:47 AM   #3
2002 19' Bambi
Boulder , Colorado
Thanks. Yes, we used it once since de-winterizing. It worked fine then. I must say, I'm stumped. The valves under the bed control pressure to the sinks as well as the shower and toilet, so all should be working.
Old 06-13-2009, 11:51 AM   #4
2002 19' Bambi
Boulder , Colorado
The solution was to sort of prime the hoses with some water in the holding tank by turning on the water pump. I also had to jiggle the kitchenette sink faucet back and forth to free up the water flow. Strange. This is s 2002 Bambi with newer fixtures.
Old 06-13-2009, 06:16 PM   #5
CountryBob's Avatar
2012 25' Flying Cloud
Manasquan , New Jersey
Just happened to me and of course I was ready to take the entire plumbing system apart when I decided to call my local Airstream dealer... He said check the strainer in the faucets... I was amazed but both the kitchen and bathroom sinks where clogged solid. I had just come back from a 6 week trip and all was working fine... I must have just picked up some sand etc.
CountryBob is offline   Reply With Quote
Best toilet/shower cleaners willyd Cleaning, Stripping & Polishing 1 10-16-2008 07:42 AM
Water Pressure Regulator & External Water Filter safarijim Off Topic Forum 7 02-01-2007 08:17 PM
Shower Pressure Skinner1 Fresh Water Systems 6 10-15-2005 06:52 PM
Relocating tanks, sinks, shower, toilet etc. Billyb Sinks, Showers & Toilets 8 11-02-2004 12:21 AM
Beginner question on value of shower/toilet dhyatt Interior Restoration Forum 6 05-08-2004 12:34 PM
