Old 07-14-2007, 04:17 PM   #1
1998 30' Limited
garden Ridge , Texas
Help!! Need access water pressure regulator
I have a 1998 Classic and I want to change the internal water pressure regulator. I bought a new one and I obviously know where the old one is. I have removed the four screws that hold it in place, but it is not coming forward to be able to unscrew the hose mounted to the back side of the regulator. There must be some trick to this deal. Any ideas?
Crawdad is offline   Reply With Quote
Old 07-14-2007, 04:36 PM   #2
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Thousand words
Originally Posted by Crawdad
... Any ideas?
Post a picture of your predicament.
BTW, most regulatators are adjustable. Your old one might work for you with a simple adjustment. We need a picture first, though.
Tom
Old 07-14-2007, 06:56 PM   #3
Desert Fox
1985 31' Sovereign
Tucson , Arizona
Talking Crawdad
Put A pressure regulator on the hose. The RV supiy house sell them for $10 or less. This way you have it all the time when you travel from campground to campground. I leave mine on the hose that I use for fresh water.
Regards from Russell in hot Tucson Az.
RUSSELL is offline   Reply With Quote
Old 07-14-2007, 07:03 PM   #4
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
The ones for the hose protect it. Since they are cheap, I have always carried one even though the internal unit protected the trailer.
Vaughan
Old 07-15-2007, 01:53 PM   #5
1998 30' Limited
The problem is that I have very low water pressure when hooked up to the city water, and I was told that the internal pressure regulator needs to be replaced. I suppose there could be some other reason for the low pressure but for now I want to replace the internal PR. Thanks for the replies.
Old 07-15-2007, 02:16 PM   #6
1983 34' Excella
1967 24' Tradewind
Images: 32
The park where I live has these on every lot placed there by the landlord. I have had that on clog twice over the years. Disassembly and a good cleaning resolved the problem without replacement. Doesn’t take long either. Might be worth a try. Good luck.
Vaughan
low drain points Raptorrider2001 1999 Safari 19 11-13-2015 01:40 PM
travelling w/out water system maznblu Fresh Water Systems 6 09-09-2002 12:03 PM
Low water pressure in Excella murf Fresh Water Systems 7 09-04-2002 07:12 AM
Water Drip uwe Fresh Water Systems 6 07-11-2002 08:39 AM
Flushing Black Water Tank ViewRVs General Motorhome Topics 3 05-16-2002 02:59 PM
