Originally Posted by Bigtuna
My bambi has no water tank, or plumbing i am starting from scratch, It would be a huge help if some one could let me know where i could buy a tank and a compressor, and a fill neck for the out side of the AS. also maybe some pics of the tank and the fill, so that i could remake them????Thank YOU All!!!!!
Pressurized water systems went out in the
1964 models. They are far more trouble than they are worth.
Converting the water system to "demand" is simple as well as cost effective.
Plastic water tanks are available for the 64 and up models, which will fit you trailer. There are many types of demand wate4r pumps available too.
The water fill spout still can be used, "if" you drill a small hole in it, so the the plastic water tank does not collapse, when the pump draws water from it.
