Old 04-13-2016, 07:20 AM   #1
sb55's Avatar
2018 30' Flying Cloud
South Hero , Vermont
Help changing fresh water tank drain
Help. My valve disintegrated and I was expecting an easy replacement. Now that I have the new part the old one it is not an easy removal. Do I have to drop the whole plastic heat shield to get to it? I see that someone drilled a slot to get to the low point drains, but that hole won't reach the drain. Or should I drill another access hole? Photo is attached. Click image for larger version
Name:	ImageUploadedByAirstream Forums1460553594.810192.jpg
ID:	260618Click image for larger version
Name:	ImageUploadedByAirstream Forums1460553630.951279.jpg
sb55 is offline   Reply With Quote
Old 04-13-2016, 09:28 AM   #2
sb55's Avatar
Well. Thank goodness for a dremel reciprocating saw. I ended up cutting it out to expose the 3" piece of plastic tubing and hose clamp. Not a very user friendly place to get to otherwise. Click image for larger version
Name:	ImageUploadedByAirstream Forums1460561205.800424.jpg
ID:	260627Click image for larger version
Name:	ImageUploadedByAirstream Forums1460561230.161049.jpg
Then a strap with self tapping screws to put it back together. Click image for larger version
Name:	ImageUploadedByAirstream Forums1460561291.971065.jpg
Old 04-13-2016, 10:08 AM   #3
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
Good job. It's maddening how Airstream feels access to maintenance items is unnecessary.
I've seen others cut a hatch below and others have dropped their water tanks.
Many do use the same drain but use a metal one.
I would put a patch over the other hole to keep debris out and warm furnace are in.
Kelvin
Fresh water tank in '07 won't drain - Help! ellenwall Fresh Water Systems 2 05-05-2009 06:23 PM
Is there a drain for my Fresh water Tank!! Mrcrowley Fresh Water Systems 1 12-02-2008 04:44 AM
Fresh Water Tank Drain NEW94 Fresh Water Systems 5 11-04-2007 08:58 PM
Fresh water tank drain valve location? trilink3 Fresh Water Systems 8 11-04-2007 08:23 PM
Really need a drain on the fresh water holding tank?? SmokelessJoe Fresh Water Systems 16 06-17-2007 07:50 AM
