Old 10-10-2011, 05:27 PM   #1
Alumaholic's Avatar
1966 24' Tradewind
Albuquerque , New Mexico
Images: 33
Has Anyone Replaced Their Petcocks?
Has anyone replaced the petcocks that drain the hot and cold water systems? Mine are leaking.
Ken L
1966 Tradewind 24
2007Chevy Silverado 2500 HD Duramax/Allison
Four Corners Unit WBCCI #8654
Alumaholic is offline   Reply With Quote
Old 10-10-2011, 05:48 PM   #2
Condoluminum's Avatar
1988 25' Excella
Sunnyvale , California
Images: 13
Send a message via AIM to Condoluminum
There was a discussion here:
http://www.airforums.com/forums/f443...lve-77057.html Different valves for different years, none seemed loveable...
Condoluminum
Condoluminum is offline   Reply With Quote
Old 10-10-2011, 06:06 PM   #3
fltlevel510's Avatar
2004 30' Classic Slideout
Between Here , And There
Found a brass replacement at Harbor Freight in the pneumatics section only $1.98 each. However after removing the old ones and lubricating well they worked fine. I use plumbers silicone grease on just about every valve on the Airstream and seems to keep them working smoothly.
fltlevel510 is offline   Reply With Quote
Old 10-11-2011, 12:34 PM   #4
Alumaholic's Avatar
1966 24' Tradewind
Images: 33
Pesky Petcock Problem Persists
Thanks for the helpful posts regarding repair and replacement of the freshwater drain. (I'm sure it's just a matter of time until I will have to replace it too.)
But right now I need petcock help.
The petcocks are fastened to the bottom of the fresh-water, holding-tank pan, as shown in my first post.
One petcock drains the hot water lines.
The other petcock drains the cold water lines.
Both are leaking.
Has anyone replaced petcocks.
Ken L
1966 Tradewind 24
Old 10-11-2011, 02:11 PM   #5
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 56
Drain Valve products, buy Drain Valve products from alibaba.com
This is what you want. Any radiator shop should be able to help you.
Dave
Old 10-11-2011, 02:54 PM   #6
dznf0g's Avatar
Oswego , Illinois
Holic, Give AS a call. If they screw directly into the bottom of the tank, it's a no brainer. Just use the wrench on the hex sided "nut" and replace. Very standard part. I'm a little afraid there may be some kind of extension between the tank and the petcock. If that's the case you could cause a leak upstream of the petcock if you just twist away. That wouldn't be good....more major surgery to fix. You'd have to cut away some tank pan and insulation to get to the tank bottom.
Old 10-11-2011, 03:00 PM   #7
Alumaholic's Avatar
1966 24' Tradewind
Images: 33
Bingo
Since the petcocks are mounted on the freshwater pan, we don't know what is going on inside the pan.
Ken L
1966 Tradewind 24
Old 10-11-2011, 04:08 PM   #8
dznf0g's Avatar
Oswego , Illinois
Correct, Call Randy McNeely at AS.
Old 12-21-2012, 01:42 PM   #9
Captain Hank's Avatar
2007 27' Safari FB SE
Summerville , South Carolina
I want to post what I did to replace my petcock drain valves.
As you know the petcocks are conveniently placed (HaHa!) behind the left side front tire. They also stick and are hard to open. The handles on mine had rusted so bad that the handle broke when I tried to open it.
I had an access cover by the valves that I could remove. I discovered that the PEX water lines connected to a 1/2" to 3/8" bushing that the petcock screws into. AS used two washers between the petcock and the bushing to secure it to the belly pan.
I disconnected the PEX lines and removed the petcock and the 1/2 to 3/8 bushing.
I purchased two small ball valves from Harbor Freight tools(Item68254). The valve has 1/4"MPT on one end and 1/4" FPT on the other end. I also purchased two 3/8' to 1/4" brass bushings.
I screwed the 3/8" to 1/4" bushing into the 1/2"to 3/8' bushing using one of the washers. This made the assembly secure to the belly pan. I then screwed the 1/4" valves into the 3/8 end of the bushing and reconnected the PEX lines. I oriented the valve handles at an angle to space between the tires. This made it easier to reach. With the ball valve it only take 1/4 turn to open the valve. If the valves ever need to be replaced, I can now screw them out of the bushing without opening the access cover.
It costs less than $20 to complete this improvement. It is now very easy to drain my piping system to winterize my AS.
I am going to try an post a couple of pictures.
ID:	174982   Click image for larger version
Captain Hank is offline   Reply With Quote
Old 12-21-2012, 02:44 PM   #10
Alphonse's Avatar
2010 28' Flying Cloud
Lower Alabama , USA
Very neat job and looks like quite durable. Will keep this in mind when the time comes!
Alphonse is offline   Reply With Quote
Old 12-21-2012, 03:14 PM   #11
sandlapper's Avatar
1993 34' Excella
York , South Carolina
Great work Henry. Another one of those minor major improvements.
John
John
WBCCI #3892 Palmetto State Airstream Club 22
Region 3 , 1st VP
Go often to the house of a friend, for weeds choke the unused path........Emerson
Are you kind?
sandlapper is offline   Reply With Quote
Old 12-21-2012, 03:18 PM   #12
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
Nope. Still have the same old rooster.
Old 12-21-2012, 04:27 PM   #13
Alumaholic's Avatar
1966 24' Tradewind
Images: 33
Elegantly done Cap'n. Thanks for the follow-up.
Mine was a less elegant fix though similar. I was a bit worried about hanging valves beneath the fresh-water, holding tank pan, so I just used caps. There is already too little clearance to make me happy.
Ken L
1966 Tradewind 24
Old 01-22-2013, 08:02 PM   #14
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
I too would be concerned with low hanging valves. I have read some threads from more than one traveler that lost a FW tank drain valve on the rough roads to / from Alaska. These would hang down even more. However, for those whose travels keep them on more improved roads I think it's a fine idea.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
petcock
Why Two Petcocks? Alumaholic Plumbing - Systems & Fixtures 6 01-15-2012 05:38 PM
Sika 721-UV to be replaced by Sika 505-UV?? mile2885 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 0 09-08-2011 07:04 PM
Replaced acrylic/fiberglass kitchen sink in 08 Classic chaimemet General Interior Topics 2 07-12-2011 04:20 PM
Does it need to be replaced? reddoor Electrical - Systems, Generators, Batteries & Solar 7 06-27-2011 05:55 AM
Replaced 2009 27FB Subwoofer with JL Audio FLMarine Audio, Video & TV 1 03-27-2011 03:18 PM
