Old 05-22-2011, 05:28 PM   #1
1997 34' Limited
christiana , Tennessee
Hard to get to water leak....
I have a 1997 34' limited with rear bed driverside bath and kitchen. My problem is a line break behind shower under bench seat.The line seems to be coming from the closet area on the otherside that is were the pump is. It is a very hard area to get to. Not sure how to approach. Any suggestions?
clint3636 is offline   Reply With Quote
Old 07-14-2011, 02:59 PM   #2
1975 31' Sovereign
1968 26' Overlander
Lost Angeles , California
I had a similar problem with my 68 overlander. Instead of tearing everything out to get to the broken part of the tubing I found the easiest place to reach on either end and replaced about 8' of the pipe all at once. As it turned out I could get to one side of the pipe under the sink with a fairly generous amount of room but crawling under the bathroom sink to cut the other end proved to be difficult. While I was in there I replaced all the copper in that section with pex so I didn't have to do it again anytime soon.
All I need is a some solar panels, and a place to park outside the smog of LA.
1968 Airstream Overlander
1975 Airstream Sovereign
TV = 1997 Ford F250HD Powerstroke
hartley1212 is offline   Reply With Quote
Advice needed on water leak and sub floor damage on 08 Int'l Westfalia Repairing/Replacing Floor &/or Frame 9 03-20-2012 05:25 PM
Water Leak bumper Airstream danyfr67 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 15 06-07-2011 07:43 PM
Fresh water leak Stearns Fresh Water Systems 8 03-24-2011 09:52 AM
Water Leak in Plumbing eldin Fresh Water Systems 8 03-17-2011 07:43 AM
Water Hose - Hard Water Deposits Al - K4GLU Fresh Water Systems 4 02-16-2011 04:00 PM
