07-24-2018, 06:45 AM
2015 28' International
Pittsburgh
, Pennsylvania
great water pressure except in kitchen
We have great pressure into the Trailer but hardly any to the kitchen sink. We've cleaned the screen on the faucet, (there was sediment), but it was no help. In fact, our repairman took the faucet apart. They can't find a problem. Any thoughts?
07-24-2018, 07:01 AM
1994 30' Excella
alexandria
, Kentucky
Trace the water lines out to see if there are any kinks in the line.
Blow out with air pressure - both ways.
The faucet may have so much gunk in it that it may be clogged internally. Disassemble and clean to the best extent possible.
Side story - when my sister bought a used trailer the hot water tank had a load of mineral sediment in the bottom. This gunk went through the plumbing system. I spent the next several hours taking every plumbing fixture apart cleaning the gunk out. The fix for this is to flush the hot water tank when winterizing, dewinterizing and a least once mid season. There is a small water wand that can be inserted into the tank for this job.
https://www.rvupgradestore.com/11691...ABE3E4DD18D0B8
Hensley Arrow hitch with adjustable stinger
WBCCI # 3072
07-24-2018, 07:11 AM
2000 25' Safari
Davidson County
, NC Highlands County, FL
^^ what he said ^^
I suggest taking the faucet screen off and let the water flow through the kitchen faucet for a while. Maybe something will dislodge.
I've used wands as suggested above. They work well.
However, another way to flush is to take the plug out of the water heater then turn on water through the city inlet. That will have enough flow to wash out the gunk.
Is this low pressure something new, a change since last season? Or, has this been a problem since the trailer was new?
Alan
07-24-2018, 07:16 AM
2013 30' Flying Cloud
Kingwood
Possible plugged in-line filter?????
Does your Airstream have an in-line filter in the kitchen waterline? My 25’ FC does and it’s under the sink countertop. It can be bypassed with shutoff valves at either end.
07-24-2018, 09:17 AM
2012 23' FB International
Woodstock
, Ontario
My Moen single lever faucet sometimes gets gunk in the cartridge. I can shake it loose by pumping the handle on/off. If your repair man took it apart then he would likely have sen this. Have you tried disconnecting the faucet and pumping water through the supply lines?....messy but it will prove a point!
JCW
07-24-2018, 09:42 AM
Pittsburgh
, Pennsylvania
This is a new problem this season. We've replaced the water heater due to a leak in the weld but the problem persists. I thought we should try blowing it out, also. Any maybe remove the plug at let it flow as suggested.
Thanks, all!
07-24-2018, 10:43 AM
1998 34' Limited
Lawrenceville
, Georgia
Is the problem the same for hot or cold?
07-24-2018, 05:15 PM
2016 30' Classic
2009 25' FB Flying Cloud
Dade City
Kitchen Faucet Pressure
We had the same problem in our 2016 Classes. Final solution is the valve above the valve that selects spray or steady stream. I removed the rubber cover and pulled the valve out...it was in the closed position... and problem solved. Hope it works for you.
