Old 09-11-2008, 07:48 AM   #1
1970 31' Sovereign
rembert , South Carolina
gravity fed from a ram pump
Hi we are new to the fulltiming scene as well the AS. My husband and I have a 1970 31' Land yacht that is serving as our semi off grid home (we have power, no well). The fresh water holding tank has been disconnected at the filler tube, the supply lines are capped off. Any thoughts why? We assume there is a problem with the tank. Is there any way to check it or take it out? Thanks, Kevin and Charlotte
cnsilver is offline   Reply With Quote
Old 09-11-2008, 08:30 AM   #2
DEITZ645's Avatar
2006 30' Classic S/O
Mohrsville , Pennsylvania
Kevin and Charlotte,
First welcome aboard.
Second the easy way to confirm a problem with the potable water tank is to just fill it and look for leaks from the tank enclosure under the trailer. The hard way is to remove the enclosure from the belly of the trailer to gain access to your potable water, gray, and black tanks.
Since you have a vintage unit and it sounds like you may be looking for parts, these two places will become invaluable
Vintage Trailer Supply
Out Of Doors Mart
Not to mention the experience and help from fellow forum members.
Carl, Elaine & Finn The Beagle
2006 30' Classic W Slide & Limited Package Katarina
2006 GMC 2500 HD 6.6 Turbo Diesel Crew Cab 8' Bed
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
DEITZ645 is offline   Reply With Quote
Old 09-11-2008, 08:51 AM   #3
We have the correct water tank, that we have specially made, for your 1970 Airstream, should you find thast you need one.
We also have more parts for the vintage trailers, than anyone in the world, since we have many of the original molds, etc.
Old 09-11-2008, 09:07 AM   #4
HowieE's Avatar
Princeton , New Jersey
Images: 12
Rather than fill the tank with water and run the risk of a leak that will be hard to locate and could cause additional problems. Remove one of the caps or if it is plastic tap into it and install a air valve. If that is a problem install an air valve at the hot water heater drain. Once installed and with all faucets turned off pump air into the tank. Just enough, a couple of pounds, that you can see the pressure on a tire gauge or hear the air escape when you open the air valve. If you hear a leak as fast as you are pumping you have found the reason. If not let it set for several hours and assuming there is no major change in temperature read the pressure again or check the pressure at the valve. Any significant drop in pressure is a leak.
2004 Excursion 4x4
Old 09-11-2008, 02:03 PM   #5
1970 31' Sovereign
Thanks, we are going to look into the pumping air idea as to the water supply is limited. When all else fails replace it!
Old 09-11-2008, 06:27 PM   #6
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
It's not hard to remove and check that water tank in a 1970's model. It should be under the floor, in front of the front axle.
You have to remove one side of the steel bars that protrude from the frame, and then slide out the plywood that holds up the tank. But make sure that the lines really are disconnected.
With the tank out, you can inspect it for cleanliness and cracks etc.
Uwe
www.area63productions.com
New Dodge Ram henw Tow Vehicles 20 03-06-2008 10:05 AM
Measuring specific gravity of battery electrolyte guy99 Batteries, Univolts, Converters & Inverters 6 01-20-2008 07:31 AM
Camping in state & fed parks BJo Off Topic Forum 5 07-18-2006 07:55 AM
FMVSS (fed. safety sticker) on Argosy MH moisheh General Motorhome Topics 4 04-12-2004 12:53 PM
i'm sick up and fed..... norbert Our Community 31 03-22-2004 08:08 PM
