05-14-2018, 11:42 PM
2013 25' FB Flying Cloud
Scotts Valley
Gasket Kit for Shurflo City Water Hookup/Regulator
Does anyone have a source for the Airstream Gasket Kit # 1, PN 365336. I am replacing the Shurflo city water hookup/regulator and discovered the gasket is and Airstream part and not included with the Shurflo. I would much rather use the foam gasket than use caulk, due to ease of changing in the future.
Gasket Kit #1, not sold separately (pn 365336):
Exterior shower gasket, 1 Ea.
City water fill gasket, 1 Ea.
Step light gasket, 1 Ea.
Awning lockdown (AS5 & AS7 Kit), 4 Ea. Lower awning foot (AS7 Kit), 4 Ea. Awning foot (Rear W/Pan Kit), 4 Ea. Lower awning foot (AS5 Kit), 4 Ea.
05-15-2018, 06:14 AM
2015 27' FB Eddie Bauer
2011 25' FB Flying Cloud
Fernandina Beach
Hi. I don’t have a direct answer to your question, but I purchased a sheet of adhesive foam gasket material, ⅜”, from McMaster online, then traced the Shurflo unit on it, cut it out, and then used a coffee mug to trace the circle for the center hole. It worked out pretty much the same as the original gasket, and I made an extra for when the Shurflo fails the next time. [emoji3] Joe
05-15-2018, 08:10 AM
Scotts Valley
Good suggestion Joe, thanks!
05-15-2018, 08:44 AM
Full time Airstreamer
2014 30' FB FC Bunk
Anywhere
, USA Living.Somewhere.Yonder
I carefully pulled the old one off and reused it. Seems to be working.
@living.somewhere.yonder | Instagram
05-15-2018, 09:45 AM
2015 25' Flying Cloud
Morton
Can I ask how you gained access to the regulator?
05-15-2018, 10:11 AM
Scotts Valley
05-23-2018, 01:35 PM
San Gabriel
I pulled mine out the outside opening once I took the screws out. I have a question...There seemed to be excessive water pressure when I unscrewed the Shurflo City Water Hookup/Regulator. I had my wife open a faucet Incase. I then put the Shurflo Unit on a hose...no leaking. When I put it back on the trailer....leaks at front of wheel well. Any suggestions?
05-23-2018, 01:45 PM
2014 25' Flying Cloud
San Luis Obispo
To get the gasket set, I contacted Airstream and they sent the set.
2014 Flying Cloud - 25' RB
2016 Tundra
Air# 42643; WBCCI# 3884
05-23-2018, 01:59 PM
2017 27' Tommy Bahama
2016 30' Flying Cloud
2014 27' FB Eddie Bauer
Hot Springs Village
, Arkansas
To clicker187,
Mine leaked and all I had to do was tighten the inside and outside screws. I did not take it off so your case may be different..
Rick
2017 27 Tommy Bahama
2020 2500 GMC Duramax
03-19-2022, 04:26 PM
2014 28' Flying Cloud
Phoenix
, AZ
rubberr gasket
I got a 6x6 sheet of rubber gasket material from Ace, just 1/16, which seems plenty thick for the application.
09-24-2023, 05:10 PM
2006 25' Safari
St. Augustine
I just took my city inlet off- 17 years old. Shurflo from factory. Here is what mine looked like- plummer's putty and dicor, it looks like.
WBCCI 8653/AIR 60240
2022 Ford F150 PowerBoost Platinum w/7.2KW
