Old 05-15-2018, 12:42 AM   #1
2013 25' FB Flying Cloud
Scotts Valley , California
Gasket Kit for Shurflo City Water Hookup/Regulator
Does anyone have a source for the Airstream Gasket Kit # 1, PN 365336. I am replacing the Shurflo city water hookup/regulator and discovered the gasket is and Airstream part and not included with the Shurflo. I would much rather use the foam gasket than use caulk, due to ease of changing in the future.
Gasket Kit #1, not sold separately (pn 365336):
Exterior shower gasket, 1 Ea.
City water fill gasket, 1 Ea.
Step light gasket, 1 Ea.
Awning lockdown (AS5 & AS7 Kit), 4 Ea. Lower awning foot (AS7 Kit), 4 Ea. Awning foot (Rear W/Pan Kit), 4 Ea. Lower awning foot (AS5 Kit), 4 Ea.
25Twin is offline   Reply With Quote
Old 05-15-2018, 07:14 AM   #2
jayseejay's Avatar
2015 27' FB Eddie Bauer
2011 25' FB Flying Cloud
Fernandina Beach , Florida
Hi. I donít have a direct answer to your question, but I purchased a sheet of adhesive foam gasket material, ⅜Ē, from McMaster online, then traced the Shurflo unit on it, cut it out, and then used a coffee mug to trace the circle for the center hole. It worked out pretty much the same as the original gasket, and I made an extra for when the Shurflo fails the next time. Joe
jayseejay is offline   Reply With Quote
Old 05-15-2018, 09:10 AM   #3
Good suggestion Joe, thanks!
Old 05-15-2018, 09:44 AM   #4
Full time Airstreamer
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
Anywhere , USA Living.Somewhere.Yonder
I carefully pulled the old one off and reused it. Seems to be working.
@living.somewhere.yonder | Instagram
SCOTTinNJ is offline   Reply With Quote
Old 05-15-2018, 10:45 AM   #5
2015 25' Flying Cloud
Morton , Illinois
Can I ask how you gained access to the regulator?
Hoboplayer is offline   Reply With Quote
Old 05-15-2018, 11:11 AM   #6
Luckily on our trailer, a 2013 25' FB it was trivial! There is a small ledge in the back of the hallway closet that is held in place w two screws. Removing these gives access to the back of the regulator and I was able to unscrew the fitting by hand! Then I removed the 4 screws on the exterior and it came right out. I was pleasantly surprised to find out the access was so easy!Click image for larger version
ID:	311024Click image for larger version
ID:	311025Click image for larger version
ID:	311026Click image for larger version
ID:	311027Click image for larger version
Old 05-23-2018, 02:35 PM   #7
clicker187's Avatar
San Gabriel , California
I pulled mine out the outside opening once I took the screws out. I have a question...There seemed to be excessive water pressure when I unscrewed the Shurflo City Water Hookup/Regulator. I had my wife open a faucet Incase. I then put the Shurflo Unit on a hose...no leaking. When I put it back on the trailer....leaks at front of wheel well. Any suggestions?
clicker187 is offline   Reply With Quote
Old 05-23-2018, 02:45 PM   #8
waltb's Avatar
2014 25' Flying Cloud
San Luis Obispo , California
Send a message via AIM to waltb Send a message via Skype™ to waltb
To get the gasket set, I contacted Airstream and they sent the set.
2014 Flying Cloud - 25' RB
2016 Tundra
Air# 42643; WBCCI# 3884
waltb is offline   Reply With Quote
Old 05-23-2018, 02:59 PM   #9
rperrym's Avatar
2017 28' Tommy Bahama
Hot Springs Village , Arkansas
To clicker187,
Mine leaked and all I had to do was tighten the inside and outside screws. I did not take it off so your case may be different..
Rick
2017 27 Tommy Bahama
2018 2500 GMC Duramax
rperrym is offline   Reply With Quote
install of shurflo pressure reducing city water entry dsrtgrls Plumbing - Systems & Fixtures 18 08-23-2018 12:02 PM
Shurflo city water regulator question dlb435 Fresh Water Systems 9 01-18-2014 05:40 PM
ShurFlo Electrical Hookup dfratini Water Heaters, Filters & Pumps 3 03-31-2011 12:33 PM
Replaced city water SHURflo pressure relief valve fitting silverback Fresh Water Systems 3 06-01-2010 02:32 PM
shurflo city water inlet urbanfood Fresh Water Systems 3 08-19-2007 04:25 PM
