Old 04-09-2016, 06:51 AM   #1
Holiday Ramblers
badib-yazdi's Avatar
2002 22' International CCD
Springfield , Missouri
Galley Faucet and Toilet Sprayer - No Water
I dewinterized for first time. To winterize I did not blow out any lines but did drain everything, opened / closed the valves on the water heater and filled with anti-freeze and run through the faucets. When I opened everything up I hooked up to city water to run all the anti-freeze out. The galley faucet and lav faucet sputtered for a while. Then the galley kitchen just stopped. Nothing coming out - air or water. Started looking around and found the screen at the entry point for city water was clogged so I cleaned it, then filled the freshwater tank w water and ran the pump to see if that would make any difference. No luck. Nothing out of galley faucet AND nothing out of toilet sprayer. The toilet itself functions. I checked the screen on the two faucets - and they are clear. No leakage under the sink, or outside that I can see. It's almost as if there is a shutoff valve just for each of these two. Any ideas? The law faucet flows just fine with city water, fresh water tank, and hot water works.
Bruce Adib-Yazdi
Beautiful Ozarks MO
badib-yazdi is offline   Reply With Quote
Old 04-09-2016, 06:58 AM   #2
Missouri Valley , Iowa
Check the aerator in those faucets. I have had mine fill with scale from the water heater or just the lines themselves. The toilet sprayer may have a removable head that you can clean out also. Or maybe put some vinegar in a container and soak the head for a while to dissolve the lime / scale.
Dan
Farmer Dan is offline   Reply With Quote
Old 04-09-2016, 09:03 AM   #3
Holiday Ramblers
Ah. I found an additional clogged screen where the flex hose on the galley faucet attaches to the sprayer handle. And the toilet sprayer, well, I did not realize you had to depress the flush valve to get water to it. Duh.
Bruce Adib-Yazdi
Beautiful Ozarks MO
Inaugural outing issues - furnace and galley faucet SusanFleck 2016 - Current Classic (all lengths) 13 04-15-2016 12:44 PM
Sprayer on hose near toilet? Kistler Sinks, Showers & Toilets 25 09-09-2015 06:41 AM
bathroom faucet with sprayer funkill Sinks, Showers & Toilets 3 05-04-2014 06:34 AM
Replacing Sink and Faucet in Galley 1Michigander Cabinets, Counter Tops & Furnishings 15 04-21-2008 11:35 PM
Toilet Sprayer Valve Leak 66Overlander Sinks, Showers & Toilets 6 06-21-2004 01:03 AM
