Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Fresh Water Systems
Old 02-23-2014, 11:23 AM   #1
huntingdon , Pennsylvania
front fresh water tank
has any one ever installed a 50 gallon fresh water tank above the floor under the couch ( were are recontructing our couch set up in the fron) and then put a holding tank in place where the fresh water used to be? we have a center bath soverign
thanks
kokomoscalls is offline   Reply With Quote
Old 02-23-2014, 12:23 PM   #2
FreshAir's Avatar
1966 24' Tradewind
Placerville , California
That will be a lot of tongue weight. Might be difficult to counter balance with weight in the rear.....given the '70s history of rear sagging.
Neil
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
Old 02-23-2014, 02:04 PM   #3
1977 Argosy 24
Milltown , Wisconsin
My 77 Argosy came from the factory with the water tank on top of the floor in the front. But the gray and black water tanks are in the rear for balance.
ventport is offline   Reply With Quote
Old 02-23-2014, 03:43 PM   #4
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Kind of makes it a teeter-totter, doesn't it? As the front tank empties, the rear tanks fill.
Old 02-24-2014, 06:32 AM   #5
1977 Argosy 24
Protagonist I never thought about it that way, but I would say you are correct.
Old 02-24-2014, 07:31 AM   #6
thanks
That would be placing way to much weight on the A-frame, that will snap off in time.
30 gallons is the design limit, as per Airstream.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 02-24-2014, 08:52 AM   #7
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Water weighs about 8lb per gallon. 50 gal. of water is ALOT of weight up front. It's a lot of weight wherever you put it, so you need to plan accordingly.
Kay
fresh water tank capt ken Fresh Water Systems 1 02-06-2014 12:03 PM
Water tank drain valve replacement lboyd Fresh Water Systems 5 12-31-2011 02:51 PM
1976 Sovereign fresh water tank drain drbseeker Fresh Water Systems 5 12-23-2011 09:38 PM
Fresh Water Tank mshamilton Plumbing - Systems & Fixtures 4 05-08-2011 02:01 PM
Convert water gravity tank to outside pressure robwok General Interior Topics 15 02-11-2011 12:00 PM
