Old 03-08-2008, 06:03 AM   #1
1972 25' Tradewind
New Holstein , Wisconsin
Freshwater tank removal on '72 ambassador 29'
Good Morning every one! It is 3 degrees outside with a -10 windchill, and I can hear the AS shivering from here! I have a question regarding the removal of the freshwater tank. I filled it last year, and when it got just about to the top, water came rushing out the undercarrige. I was just wondering if it is easier to go through the bottom, or remove some of the floor inside. Any help would be greatly appreciated! Happy streamin'.
shvlnr is offline   Reply With Quote
Old 03-08-2008, 07:19 AM   #2
47WeeWind's Avatar
1948 16' Wee Wind
1953 21' Flying Cloud
Denver , Colorado
Images: 20
Just a poke in the lake here, but that water might have come from an overflow value in your water tank, there to prevent it from being overfilled. I don't know if your trailer has one, but I'd look for one before ripping out the water tank. Just a thought ...
Fred Coldwell, WBCCI #1510, AIR #2675
Denver, Colorado - WBCCI Unit 24
Airstream Life "Old Aluminum"
Airstream Life
"From the Archives"
47WeeWind is offline   Reply With Quote
Old 03-08-2008, 07:28 AM   #3
1972 25' Tradewind
Thank you 47WeeWind. I never even thought of checking for that. I was just going to start removing panels and see what I would find. Thanks again!
Old 03-08-2008, 08:00 AM   #4
The water tank, can easily be remove from the bottom of the trailer.
Your water system, does not have any over flow devices.
Old 03-08-2008, 08:05 AM   #5
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
But your tank does have a vent hose thats on a nib that can fracture off easily, or have the hose pulled off it. Should be an easy check with flashlight and mirror....
Old 03-08-2008, 02:04 PM   #6
1972 25' Tradewind
Thank you Andy and Wabbiteer for your information. I was a little nervous starting this project, but your advice changed my mind. I am going to start as soon as the weather permits!
Old 04-08-2008, 11:00 PM   #7
1972 31' Sovereign
San Francisco , California
how do I remove the F W tank from my 72 sovereign Please
Maddie is offline   Reply With Quote
Freshwater Tank drain crazeevw Classic Motorhomes 9 10-28-2011 08:16 PM
Removal of 1973 fresh water tank Belegedhel Fresh Water Systems 6 08-05-2011 07:32 AM
Chlorine Alternative for Freshwater Tank Hummingbird Fresh Water Systems 16 07-06-2011 08:25 PM
Help-dewinterizing and no water off freshwater tank bonginator Water Heaters, Filters & Pumps 6 06-12-2011 08:37 PM
Fresh Water Tank Removal Stork Fresh Water Systems 6 03-04-2011 10:46 PM
