Old 06-11-2014, 01:35 PM   #1
TinTin's Avatar
2009 23' FB Flying Cloud
Canmore , Alberta
Freshwater Tank, Newbie Questions
There are three petcocks on the freshwater tank of my 23 footer. One is white plastic, located on the lower side of the tank, obviously the main tank drain, though the draining process is very ssssslllllooooowwwww. I'll try pushing air in through this drain in the next few days to see if I can clear the 'blockage'.
There are also two metal petcocks located on the bottom surface of the tank, not far from the plastic drain. These appear to be pressurized, one flows hot and the other cold. Can someone fill me in on the purpose of these two metal petcocks?
Many thanks in advance.
Bob and Nancy
http://www.rwcphoto.smugmug.com
Cheer Up, Slow Down, Chill Out!
TinTin is offline   Reply With Quote
Old 06-11-2014, 01:40 PM   #2
murreywalker's Avatar
2013 25' FB Flying Cloud
2011 23' FB Flying Cloud
Branson , Missouri
There is one freshwater drain. That is the one with the white peacock.
The other two are your low point water drains.
2013 25 FC FB (Twin)
2013 Suburban 2500
http://www.pbase.com/murreywalker
2011 23 FC FB
murreywalker is offline   Reply With Quote
Old 06-11-2014, 01:43 PM   #3
TinTin's Avatar
Canmore , Alberta
Thanks, MW.
Bob and Nancy
Old 06-11-2014, 02:25 PM   #4
Branson , Missouri
You're welcome!
BTW, I don't think your 2009 came with a white peacock; probably just a white petcock, huh? ;-)
2013 Suburban 2500
2011 23 FC FB
Old 06-11-2014, 04:44 PM   #5
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Originally Posted by murreywalker View Post
You're welcome!
But did it come with a pink flamingo?
Old 06-11-2014, 06:37 PM   #6
TinTin's Avatar
Canmore , Alberta
Ha!! gotta love that spellchecker!!
Bob and Nancy
Filling freshwater tank, newcomer needs help! thundercakes Fresh Water Systems 1 09-13-2006 09:05 PM
freshwater tank hole.......material and plastic weld kits... leefields Fresh Water Systems 4 02-06-2006 06:44 AM
['77 23' Safari] Drain valve location for freshwater tank ? Mike B Fresh Water Systems 6 11-05-2003 10:22 PM
Freshwater tank leaking - can it be repaired? drboyd Fresh Water Systems 3 09-13-2003 10:03 PM
Overflow hose in freshwater tank is loose. TBKP's Overlander Fresh Water Systems 1 08-03-2003 08:46 PM
