Old 06-19-2016, 09:45 PM   #1
1990 29' Excella
baltimore , Maryland
Freshwater system... valve and pump
I tried out the fresh water system today on 1991 excella 29.
with external water pressure, I pushed auto fill. I heard a small
noise and then could faintly hear water noises.
I left it on for awhile and the fresh water fill indicator never
rose above the enitial empty indication.
I assumed the indicator is inaccurate.
I shut the auto fill. I shut off the external water. I turned on the
water pump.
I heard the pump running. Sounds like its under the wardrobe
closet at mid ship.
It never turned off.
I do get some flow at the sink. Not near enough to run the shower.
Ideers?
thanks,
groundhogy
groundhogy is offline   Reply With Quote
Old 06-20-2016, 02:19 AM   #2
1991 25' Excella
Stanfield , Oregon
The auto fill option takes hours to work. When working correctly ( which it didnt often) it would allow a small portion of water to flow to the fresh water tank. Once the fresh water tank is at 80% it shuts off. Your best option is to fill your fresh water from your curb side port. Also it doesn't use your water pump to work, Its an electric solenoid in the piping.
SpletKay06 is offline   Reply With Quote
Old 06-20-2016, 08:24 PM   #3
1990 29' Excella
I wasnt aware that there was another water input other than the main one.
Old 06-21-2016, 01:20 AM   #4
1991 25' Excella
Stanfield , Oregon
On mine there is a city water hookup on the roadside and a fresh water fill port on the curbside (its behind a door above the fender)
Old 06-23-2016, 05:11 PM   #5
1990 29' Excella
fill.
Found it. Thanks
1978 Excella 500 31' freshwater system - what are these two things? Jcashcollect Waste Systems, Tanks & Totes 18 03-01-2016 11:49 PM
Question About 2008 Classic 25 Freshwater System KJRitchie Fresh Water Systems 1 04-24-2013 10:44 AM
Freshwater pump on '76 Treyladut Fresh Water Systems 2 08-28-2011 09:31 PM
New Freshwater System Skycop Fresh Water Systems 26 03-16-2009 10:36 PM
['77 23' Safari] Drain valve location for freshwater tank ? Mike B Fresh Water Systems 6 11-05-2003 10:22 PM
