Old 08-28-2011, 09:05 PM   #1
Walker , Louisiana
Freshwater pump on '76
I have a 76 31ft sovreign with rear bath.where is the fresh water pump located? I hit the switch and nothing happens and I looked for it and can't find it.
Treyladut is offline   Reply With Quote
Old 08-28-2011, 09:28 PM   #2
Mexray's Avatar
1978 28' Ambassador
Morada , California
Our 78, 28ft rear bath has the FW pump mounted at floor level, below the bath cabinet, on the port side (road side)...
There is a flat panel that slides up to gain access to the pump and the back of the water heater...
If yours is similar, it should be there close to the rear bath...
Ray & Pat; Morada, CA
Old 08-28-2011, 09:31 PM   #3
Splitrock's Avatar
Sioux Falls , South Dakota
I don't know where the pump is on a rear bath. My pump is right above the tank just behind the entry door under the kitchen range/oven.
Inspecting fuel pump and tank interior DaveFL Land Yacht/Legacy Motorhomes 2 08-19-2011 06:13 PM
PAR pump not working ckbailey97 Water Heaters, Filters & Pumps 9 07-14-2011 05:01 PM
Bad Check Valve in Pump??? tinbender Water Heaters, Filters & Pumps 3 06-16-2011 06:56 PM
Water pump leaking between head and motor Ezmoneybcs Water Heaters, Filters & Pumps 4 03-20-2011 06:32 AM
Is it a water pump or an electrical problem? Taj MaHaul Water Heaters, Filters & Pumps 7 01-23-2011 07:20 AM
