Old 02-28-2011, 05:37 PM   #1
1974 Argosy 24
New Orleans , Louisiana
freshwater drainage?
Just filled my 1974 argosy trailer with fresh water & bleach to clean out the plumbing. DC pump works great, etc. but how do I drain the freshwater tank without running all of the water through the graywater system? There is what looks like a drain located directly in front of the tank, but I can't get it to open & when I look under the trailer, I don't see the hose where it would presumably drain out of.... any advice would be helpful. (The first of many questions to come )
-Lauren
lacraig819 is offline   Reply With Quote
Old 02-28-2011, 07:33 PM   #2
noreen&sal's Avatar
1981 27' Excella II
mays landing , South Jersey
On mine there is a drain between the axles on the road side. Not to hard to reach. Sal.
Sal & Nora
Let us live so that when we die even the undertaker will be sorry. Mark Twain
AIR 42483
TAC N.J. 17
WBCCI 24740
noreen&sal is offline   Reply With Quote
Old 02-28-2011, 07:43 PM   #3
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Find the main water feed line from the tank to the pump....its a short one normally. That line probably will split to two valves...one of those valves will be the drain.
(Remember now, I am the one who flooded my trailer last week with those same two valves)
Old 02-28-2011, 10:15 PM   #4
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Try again.
When you say you can't drain the tank; Is it that nothing comes out when you turn the handle on the valve to drain it? If you can turn the valve handle and you have turned it and nothing comes out, try turning it the other way. The valve on the tank in my '74 will only drain when the valve is in that position.
