Old 02-17-2014, 10:42 AM   #1
1992 29' Excella
Fort Davis , Texas
Freshwater drain plug
On my 1992 Excella the drain plug was damaged as well as the housing the plug threads into. I thought-mice ! Maybe so but I tried caulking the threads & reinstalled the plug. Still leaked. The housing is pretty bad so I tried epoxy, clamping a plastic band to keep the epoxy in place. Most of the leak is gone but there is still one at the top of the housing. I will try more epoxy but if that doesn't work how can I install a new drain plug assembly without removing the tank ?
dino72 is offline   Reply With Quote
Old 02-17-2014, 04:54 PM   #2
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Have you tried a brand-new drain plug in the same housing? Before you replace the whole kit-and-caboodle, you might try replacing just the plug first. And if that doesn't help, THEN replace the whole thing, but keep the new drain plug you bought as a spare.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 02-17-2014, 05:56 PM   #3
1992 29' Excella
Fort Davis , Texas
Yes I did but the housing was damaged, seemingly eaten by mice as there was debris on the inspection plate. Still hoping the epoxy will seal it.
Freshwater Tank drain crazeevw Classic Motorhomes 9 10-28-2011 08:16 PM
1977 airstream tradewind freshwater drain lance3787 Fresh Water Systems 2 08-07-2011 10:29 PM
freshwater drainage? lacraig819 Fresh Water Systems 3 02-28-2011 10:15 PM
