Old 11-20-2019, 01:05 PM   #1
Fresh Water Valves?
Can someone confirm where these two valves drain from? Why is there rust - dripping over the years? I am nervous about simply taking pliers to these two valves! I have a 2002 Classic. There is a third valve - that I think is the fresh water tank drain. Click image for larger version
ID:	356582 Click image for larger version
umasslax is offline   Reply With Quote
Old 11-20-2019, 01:19 PM   #2
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Plastic is fresh water tank drain. The others are water system low point drains. Might want to spray PB BLASTER or similar on threads and take it easy turning them.
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 11-20-2019, 05:38 PM   #3
Thanks. Did just that today. And will follow up again tomorrow and gentle turn over the weekend.
Old 11-23-2019, 08:59 AM   #4
Did just that. CCW gently turn with 10 inch vice grips and they opened easily. Wish I knew where to get new ones - even just the inner valve screw. Thoughts?
Old 11-23-2019, 01:21 PM   #5
GCinSC2's Avatar
I've never replaced any, but they look just like petcocks or drain cocks. The unknown is the connection to the plumbing system. Drain cocks are pipe thread. You may not just want to turn out w/o making sure the fitting is secured and your not turning against the pipe.
S/OS #001
Old 11-25-2019, 07:43 PM   #6
honi soit qui mal y pense
Robere's Avatar
2015 23' FB Flying Cloud
Bend , Oregon
FW Plastic Drain valve
Check out my previous post from a few months ago. The plastic valve is fragile and I suggest popping it out by pressing from the bottom rather than trying to turn it. There are a few great ideas in previous posts by others to improve reliability. Best attempted when the weather is agreeable and you can improve the trailer height.
Robere (aka Pepe) & Jacqueline (aka Gigi)
with pups Ella (the miniature poodle)
and Tibet (the Lhasa Apso)
2016 Chev Silverado LT Crew 4x4
Robere is offline   Reply With Quote
Old 11-30-2019, 01:03 PM   #7
2014 25' FB International
Santa Cruz , peterputt
Our low water drain setup 2014 25' Int'l. Located thru fresh water tank panClick image for larger version
ID:	357076Click image for larger version
peterp is offline   Reply With Quote
Fresh water tank repair and rebuild black and grey water valves Sierra Skier LP Gas, Piping, Tanks & Regulators 0 07-25-2018 11:55 AM
Can old LP tank valves be upgraded to OPD valves? jimblacker LP Gas, Piping, Tanks & Regulators 8 03-26-2014 07:07 AM
Fresh water drain valves amazingwoody Fresh Water Systems 8 06-14-2013 08:11 PM
Identification of Valves behind Fresh Water Drain BigGrey Plumbing - Systems & Fixtures 7 07-26-2012 06:36 AM
Valves and Valves smily Plumbing - Systems & Fixtures 5 08-22-2002 05:01 AM
