Old 09-02-2006, 08:46 PM   #1
Dano57's Avatar
1979 31' Excella 500
Edmond , Oklahoma
Fresh Water Tank Vent
Still working on replacing the repair fresh water tank in a 79 Excella 500 and realized that the vent line that comes from the tank to the filler opening has not been attached to the external vent. All of the filler opening and vent seems to be contained under the wheel well skirt inside the trailer. It seems to me that the only way to reattach it is to remove the fender skirt inside, is that correct? The attached pic shows a large hose with white bands on the right side, the vent hose is partially visible on the right side of the lager hose and you can see how both go into the plastic fender skirt.
If so I think I'll cut an access panel as removing the skirt would be a major pain.
Dan
Dano57 is offline   Reply With Quote
Water Heater Craig 1978- 1979 Excella 500 7 10-01-2007 06:16 PM
Fresh water tank cleaning Krazykraut Airstream Motorhome Forums 7 01-16-2003 10:29 PM
Water Heater & Water Tank mgordon Water Heaters, Filters & Pumps 23 01-15-2003 07:58 PM
Sanatizing the Water Tank? 68 Suburban Fresh Water Systems 3 10-13-2002 01:22 PM
Water Tank Pan Craig Fresh Water Systems 7 09-06-2002 09:52 AM
