Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Fresh Water Systems
Old 07-24-2003, 10:18 AM   #1
drboyd
drboyd's Avatar
Profile:
Fresh water tank - slow drip
No, not me - the tank! Don't listen to my wife when she talks about me like that!
Seriously, I've got a slow drip out of the drain fitting at the bottom of the fresh water tank. It looks like it's been repaired at least once before, as there's a patch panel (with some ever-so-lame rusty steel screws holding it on) right at the drain area.
Couple of questions: What is the tank material? Is it plastic, aluminum, reprocessed compressed cardboard, or what?
What's the repair consensus?
Is the largest wrenchable fitting part of the tank, or does it unscrew?
I really don't want to wrench on the wrong thing and tear out a big hole in the tank!
Thanks for all the help and advice I know I'll get!
Don
Old 07-24-2003, 10:25 AM   #2
Safari Tim
a.k.a. Ambassador Tim
Safari Tim's Avatar
Profile:  1960 28' Ambassador
Northern , California
Images: 35
I found mine was leaking as well.
I was able to remove it by unscrewing it. I got a new fitting from the hardware store, and replaced it using teflon tape on it.
Seems to be holding so far....
-Tim
theVAP - Airstream Podcast | My Airstream Home Page | My Photo Gallery
Old 07-24-2003, 01:31 PM   #3
qqq
qqq's Avatar
Profile:
Tim,
Did you need to cut a chunk out of the floor to get to the leak?
& how can this water tank be removed if needed?
Hart
qqq is offline   Reply With Quote
Old 07-24-2003, 02:32 PM   #4
Safari Tim
Safari Tim's Avatar
Images: 35
Luckily for me, my tank output is accessable from inside the kitchen cabinet. It is below the floor, but the is an access point there.
It was a big pain to do and lots of colorful verbs were used. But I did it. I also replace all the plumbing and hoses and clamps to the water pump at the same time. As well as a new drain valve.
I only have one output from my tank. It tees off to a drain valve and the input to the water pump.
-Tim
Old 07-24-2003, 05:54 PM   #5
john hd
john hd's Avatar
Profile:  1992 29' Excella
madison , Wisconsin
Images: 40
just did mine.
don,
that hokey looking hole and patch panel are most likely from the factory.
look here
http://www.airforums.com/forum...&threadid=5206
john
Old 07-24-2003, 07:01 PM   #6
drboyd
drboyd's Avatar
Profile:
John hd, your first picture...
...is exactly what mine looked like, except that I don't have a separate drain petcock. Except that mine had a galvanized slash rusted 1 1/2 fitting screwed into the tank threads.
Now, in fact, a couple of hours later, I have a 1 1/2 threaded PVC plug with some teflon tape.
I also bought another setup from Homey Depot that lets me unscrew just a 1/2' plug. If I get ambitous, I'll change it over. I was a little hinkey about having anything hang down too far right there.
Fresh water tank leak Flex Fresh Water Systems 3 09-30-2004 04:25 AM
fresh water tank filling system nickcrowhurst Fresh Water Systems 5 03-16-2004 12:37 PM
Installing fresh water tank warrencindy Fresh Water Systems 6 02-17-2004 02:59 PM
Problem Filling Fresh Water Tank DaveJ Fresh Water Systems 8 10-14-2003 05:36 PM
Leaky fresh water tank nellie the elephant Fresh Water Systems 3 10-13-2003 02:12 PM
Cooking Forum - Sailing Forum - Early Retirement
Airstream Trailer Forum - Aquarium & Reef Forum
Royal Forum - Book and Reader Forum - Yoga Forum
Volkswagen Touareg Forum - Jeep Wrangler Forum
Whitewater Kayaking & Rafting Forum - Yoga Forum
U2 Forums
